So I drained the gas (thinking water had accumulated), replaced the fuel lines, and has the carb cleaned. Upon putting it back together, it appears one carb is leaking gas profusely from a small hole on the front side (under the bowl?) I'll try to attach a pic. There's a screw associated with the hole; I wonder if it wasn't something the shop left open? Does that screw close the hole, and should I tighten it? I know carbs work by science and dark magick - mostly dark magick - and that's about as much as I dare mess with it.
Is this an overflow? Am I getting too much gas to the carb? I did have to replace the Y in the fuel line that splits between the carbs and the tank. I couldn't find a Y fitting, and opted for a T fitting. (The fuel goes straight through the top of the T to the carbs)
I know diagnosing stuff via the internet is a little crazy, but I'm hoping this is just one of those "well DUH" things.
{Looks like I'll have to edit the picture before I can upload it}
