headlight ducati 750--900 sport.
900SS90
Post by 900SS90 »
I need a headlight for my 900 European, I have the one of my English motorcycle, not valid to drive in Europe.
If you are in England and have the same problem, I can make a change.
If you have a European one, for sale, on your shelf, I can also buy it.
HIGHWAY89
Re: headlight ducati 750--900 sport.
Post by HIGHWAY89 »
Gday mate, if the English light is the same as Australian I could do a swap as I only have the European unit, if that would help, cheers
Frank.61
Post by Frank.61 »
Just in case you do not succeed: a new one (CEV 287 288).
https://www.ebay.es/itm/FARO-ANTERIORE- ... 2855320827?
Good luck! :thumbup:
Frank.61
Post by Frank.61 »
Please do check the CEV numbers on your headlight, to be sure it's the correct one.
Frank, that headlight for the later 900SS does not fit the 89/90 900SS which used the same one as the 750Sport and F1.
HIGHWAY89
Post by HIGHWAY89 »
Anyone know the correct CEV numbers for the aussie headlight, cheers
Just have a look at the parts catalog :truck:
067038200 is for rhs traffic
067038210 for lhs
Frank.61
Post by Frank.61 »
If someone has a clear picture of the headlight with brand (CEV, Carrello etc.) and numbers or even the dimensions I can try to find out whether it was also used for other vehicles (Fiat?).
Production numbers were so low in the mid eighties, chanses are it was not a "Cagiva special".
If I could get the dimensions also it would be helpfull.
Just let me know if you want me to look for a source .....
I hardly know the 900ss but I've done this exercise a few times for my Bimota and some Cagivas a few years ago.
First items I search for/buy when I have a restoration project are all items related to lights and rubber parts.
900SS90
Post by 900SS90 »
Then I will go to my garage, I will try to photograph the two lighthouses.
I've tried it before, but the numbers are not clearly seen by the reflection of the crystal.
I'll try again.
900SS90
Post by 900SS90 »
Frank.61 wrote:If someone has a clear picture of the headlight with brand (CEV, Carrello etc.) and numbers or even the dimensions I can try to find out whether it was also used for other vehicles (Fiat?).
komme aus der Garage zurück
Dies sind die Anzahl der Scheinwerfer und die Maße.
Der Leuchtturm rechts und der Leuchtturm links.
Es wäre für alle gut, zu wissen, ob ein anderes Fahrzeug die gleichen Scheinwerfer hat.
Grüße
hOMOLOGACIONES FARO EUROPEO.jpg (29.32 KiB) Viewed 27856 times
Faro 2.jpg (128.16 KiB) Viewed 27856 times
Faro 1.jpg (128.83 KiB) Viewed 27856 times
900SS90
Post by 900SS90 »
hOMOLOGACIONES FARO INGLES.jpg (19.67 KiB) Viewed 27856 times
Faro 4 (2).jpg (126.19 KiB) Viewed 27856 times
Faro 4 (1).jpg (118.82 KiB) Viewed 27856 times
900SS90
Post by 900SS90 »
Medidas faro.jpg (76.6 KiB) Viewed 27853 times
Frank.61
Post by Frank.61 »
So that I understand it correctly: do you need a CEV 304 or a CEV 364?
The CEV 304 I see new ones on ebay, no 364 though ....
900SS90
Post by 900SS90 »
Frank.61 wrote:So that I understand it correctly: do you need a CEV 304 or a CEV 364?
Danke Frank :thumbup:
900SS90
Post by 900SS90 »
HIGHWAY89 wrote:Gday mate, if the English light is the same as Australian I could do a swap as I only have the European unit, if that would help, cheers
I still have the English lighthouse, for the left.
HIGHWAY 89, do you still need it?
You have a PM
