It is currently Thu May 23, 2019 6:51 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: Mikuni carbies
PostPosted: Tue Nov 06, 2018 10:36 am
Now to work out how to connect the cables , to carburetor first with throttle disconnected ? I cant see throttle first as its bloody fiddly trying to connect cables to carburetor while the cables are short and the carburetor is in position
PostPosted: Tue Nov 06, 2018 10:38 am
Once again the bottom cable is easy
PostPosted: Tue Nov 06, 2018 11:51 am
Still working on it but carburetor still in place with both cables connected there and throttle split on bar with closer taken out to thread through the carbie now I just have to sort the throttle so alls coming together
PostPosted: Wed Nov 07, 2018 9:59 am
Throttle hooked up , now I'm having trouble getting both butterflies to crack open at tha same time, ignorance showing here, however I need advice once again so thanks in advance
PostPosted: Wed Nov 07, 2018 10:26 am
Yeah it's quite a big delay so not so far able to see how to counteract that :shock:
PostPosted: Wed Nov 07, 2018 12:34 pm
Google "mikuni throttle syncronisation" .
PostPosted: Thu Nov 08, 2018 10:29 am
Major dummy spit and now this thread will end as I just ebay ordered a new set of fcr 41 dual carbies , still in shock
