wanted rubber oil sensor boot
steveT2
Post by steveT2 »
Does anyone know if the rubber oil switch boot is available from anywhere ? Fingers crossed.... Steve
Re: wanted rubber oil sensor boot
Stein Dinse lists this as an alternative
https://www.gutsibits.co.uk/pr/TheShop/ ... rch=SEARCH
It's the same piece used for the brake master pump.
Frank.61
Post by Frank.61 »
Was there a rubber booth?
Pic?
in the parts catalog ;)
#037141445
also according to SD this one should be an alternative as well: https://www.gutsibits.co.uk/pr/TheShop/ ... rch=SEARCH
steveT2
Post by steveT2 »
