Broken Neutral Switch
Rickman
Post by Rickman »
Duc906
Re: Broken Neutral Switch
Post by Duc906 »
Rickman wrote:I installed a new copper washer on my leaking neutral switch, it just began to snug when the head of the switch broke off. The plunger itself is all that's holding the head to the threads. If I break the head off I think getting the threaded part out of the engine case won't be too bad, but, I fear the plunger part of the switch will fall into the motor. So my question is; If the clutch assembly is completely removed can I access the backside of the neutral switch?
Hi Rickman
It depends on where the switch is broken.
-If it's broken at line A then you should be ok to unscrew the switch without issue as the plunger should still be retained in the head.
-If it's broken at line B, I think this is what you're describing, then you may need to get at the back of the switch, unfortunately you will have to split the cases to do that.
You might have some luck if you can get some locking pliers onto the head an apply a pulling force while trying to unscrew the switch.
Ducati Neutral Switch_a.jpg (208.98 KiB) Viewed 29101 times
Rickman
Post by Rickman »
Derek
Post by Derek »
Rickman
Post by Rickman »
Derek
Post by Derek »
Rickman
Post by Rickman »
Derek has a point but if the switch has broken off in position B and only the hollow & threaded part of the switch is left, the spring may have already jumped/fallen out. If not I'd probably remove it and insert a little bit of silicone sealant to secure the plunger from falling into the engine. If the threaded part doesn't turn it is possible you screwed in the switch too far and there's pressure on it in which case putting the engine into gear may help. Once it's loose you may be able to get it out with the eraser side of a pencil or something similar that has grip. If it's sitting tight and depending on how long the spring was, inserting a torx key may also be an option. You could also find a long thin bolt and glue it in. Best to do the last two when the gearbox in is neutral.
I'm still wondering why the switch snapped off. If you're still using the old one how thin was the new copper washer you used? The original one is 1.5mm.
Post by Tamburinifan »
Rickman
Post by Rickman »
Duc906
Post by Duc906 »
Good outcome :thumbup:
