It is currently Sat Oct 31, 2020 1:22 am
 Post subject: Engine oil grade
PostPosted: Fri Apr 05, 2019 4:05 pm
What oil grade are you using on your 900ss or 750 Sport..
Only thinking about this as on its last service the Ducati specialist used a 10w40 which I know is correct on the later bikes, but on my F1 the recommended oil is a 15w50 and I seem to recall this is correct? More as the bike is only used in summer....
A subjective subject, but this makes a interesting read, Norton related but maybe not a million miles away from our Ducati’s ?
https://www.accessnorton.com/Oil-Tests/NortonOil.php#3
 Post subject: Re: Engine oil grade
PostPosted: Sat Apr 06, 2019 8:26 am
I've always used 10w40 in the 907 and previous Ducatis until I bought a 1200 MTS. It and all newer Ducatis, including my Scrambler and Supersport, use a 15w50 so Ducati must have a re-think about oil. I'll probably move them all to 15w50 as it will save me buying 2 grades of oil.
I use this 10w40 in the 907 https://www.silkolene.com/motorcycle/4-stroke-engine-oils/comp-4-10w-40-xp/
For the Scrambler I use Silkolene Pro 4 15w50 XP https://www.silkolene.com/motorcycle/4-stroke-engine-oils/pro-4-15w-50-xp/
The Supersport is still under warranty so has been dealer serviced with Motul 300V 15w50 up to now. https://www.motul.com/us/en-US/products/300v-factory-line-road-racing-15w50
PostPosted: Thu Apr 18, 2019 9:43 am
Thanks....,,,
