Hey Jonathan -
I'm going through the PDF to do the wiring upgrade for improved starting (the addition of 2 new 30a/12v relays) and I just realized an inconsistency:
In Step 5 , you clip then pull the 12ga brown wire from the main power feed plug under the tank, attach a female push-on connector and indicate it will be connected to terminal #30 on the relay.
Later, in step 7, you add the 30a inline fuse to the battery feed post on the starter solenoid with a ring terminal, and attach a female push-on connector to the other end - and that will mount to post #87 on the relay.
However - and here's the conundrum - in the diagram under step 9, you show the "Power feed from starter solenoid. 30 and fuse" going to the vertical post #30, and the "Brown wire cut from the harness that goes to the fuse panel" connected to horizontal post #87. Those are backwards from the written instruction.
So ... Which is the right one?
Thanks in advance!
Jake
750 ignition wiring upgrade (attn. jcslocum)
- fasterdammit
1988 Paso 750 #753965
1997 Monster 750
1997 Monster 750
Re: 750 ignition wiring upgrade (attn. jcslocum)
Jake,
it doesn't matter. It'll work both ways. Contact 30 and 87 of a relay are not directional.
If you want to stick on what's printed on the relay 30 is the number for battery +.
- fasterdammit
Oh, good to know. Makes sense. I wound up running the battery+ from the starter solenoid to post #30 anyway. But what you said makes perfect sense - a switch is a switch. Thanks, G.paso750 wrote:Jake,
Hope you're doing well - it's been a while!
1997 Monster 750
1997 Monster 750
