Rear shock size
AmcG
year: 1985
Rear shock size
Post by AmcG »
Hi
Can anyone confirm the dimensions for the rear shock?
Length eye to eye- 365mm
Eye holes -10mm
Across flats -22mm
Many thanks
Alistair
Re: Rear shock size
the dimensions
AmcG
year: 1985
Re: Rear shock size
Post by AmcG »
Hi
Once again, super helpful.
Alistair
Ronald
Re: Rear shock size
Post by Ronald »
Hi Alistair,
Maybe this is also interesting for you: the 'technical data sheet' of the Öhlins DU508 shock absorber which was installed on the first 950 or so 750 Paso's. The form is named 'Mounting instruction', but there are no instructions on it whatsoever :) Nevertheless, there are some sizes on it.
Oehlins DU508 shock absorber- Ducati 750 Paso.png (43.48 KiB) Viewed 12916 times
AmcG
year: 1985
Re: Rear shock size
Post by AmcG »
Ronald
Thank you! It confirms the length.
Alistair
Re: Rear shock size
only in the very early P750 not in the 906 or 907IE
AmcG
year: 1985
Re: Rear shock size
Post by AmcG »
New shock...
