Hi
Can anyone confirm the dimensions for the rear shock?
Length eye to eye- 365mm
Eye holes -10mm
Across flats -22mm
Many thanks
Alistair
Rear shock size
Re: Rear shock size
the dimensions
- DSC00762.JPG (233.35 KiB) Viewed 8647 times
- DSC00760.JPG (209.93 KiB) Viewed 8647 times
- DSC00761.JPG (222.78 KiB) Viewed 8647 times
Re: Rear shock size
Hi
Once again, super helpful.
Alistair
Alistair
Re: Rear shock size
Hi Alistair,
Maybe this is also interesting for you: the 'technical data sheet' of the Öhlins DU508 shock absorber which was installed on the first 950 or so 750 Paso's. The form is named 'Mounting instruction', but there are no instructions on it whatsoever
Nevertheless, there are some sizes on it.
- Oehlins DU508 shock absorber- Ducati 750 Paso.png (43.48 KiB) Viewed 8592 times
Re: Rear shock size
Ronald
Thank you! It confirms the length.
Alistair
Alistair
Re: Rear shock size
only in the very early P750 not in the 906 or 907IEthe Öhlins DU508 shock absorber which was installed on the first 950 or so 750 Paso's
Re: Rear shock size
New shock...
- 8030CE54-DF89-4242-94D0-A6DDDD0F4CEA.jpeg (24.84 KiB) Viewed 8468 times
