koko64 wrote:Great job and excellent update interpretation of the style.![]()
I note that it has Mikuni TM carbs. Are they TM36 or 38's and are you happy with them? What jetting did you have to run with pod filters?
I am thinking about putting a kit together for 750 and 900 desmos as an alternative to the very expensive Keihin FCRs.
Hello! I am running TM36's with the following jets:
Starter Jet: #40 Vertical carb, #20 Horizontal carb. I found this arrangement to work best on cold starts for me.
Pilot Jet: #25 both carbs
Air Jet: #1.2 both carbs
Jet needle: #6FJ40 both carbs
Needle Jet: 389 series Q2
Main Jet: #210 both carbs
Needle Valve: #1.8 both carbs. This relieved the float bowl overflow, especially the horizontal carb.
Low profile pod filters, size 58-62 mm came from MikuniOz
I uploaded the PDF with the Sudco and Mikuni part numbers
https://drive.google.com/open?id=1U7d4_ ... N4t-CSXYxa
