Plug identification?
Crumpati
- year: 1993
Hi there, can anyone tell me what the two plugs are that along the top frame rail on the lefthand side? Two identical with the C shaped spring clip joining them. One seems to go into the housing near the clutch slave. I think they are both labeled "Conne Commando" In the parts diagram, thanks
nickta
Re: Plug identification?
Inductive pickups for the Ignition possibly? The wiring (2 wires in each) that goes into the loom will have an orange and grey/black wire in one and violet/black and yellow/blue in the other. Labelled 33 and 34 in the wiring diagram.
Don't mix them up. Engine won't run or run really badly if it does start. There is a post on the forum about this somewhere...
Cheers.
Nick.
Cheers.
Nick.
