HELP NEEDED Regulator Wires Brown & Pink
manx57
Post by manx57 »
Hi, Could someone help me please am pulling my hair out!!
I have a replacement regulator which only has 2 x red wires, 2 x yellow and 2 x Green wires.
My bike has 2 x red, 2 x yellow, 1 x Brown and 1 x pink, I have looked through pages and pages of info on the regulator and cannot see any info on the brown or the pink wire. I know the yellows go together as do the reds and I believe the greens are both earth? It is the brown wire and pink wire which originally were in a rubber connector and plugged into the old regulator I have not a clue where they go. Any help would be greatly appreciated
Re: HELP NEEDED Regulator Wires Brown & Pink
You have 2 red and 2 yellow, a brown and a pink wire? That's interesting as those are the colours that can be found on the 907IE.
According to the wiring diagram the 906 would have 2 pink, a red, an orange and a red/black, a light blue and a brown wire.
Is there anything stamped on the regulator/rectifier, a model or number which could help identifying it? If not, please post a picture.
manx57
Post by manx57 »
paso750 wrote: ↑Tue Aug 16, 2022 9:02 am You have 2 red and 2 yellow, a brown and a pink wire? That's interesting as those are the colours that can be found on the 907IE.
This is a photo of the wires on the bikes harness
The new regulator
manx57
Post by manx57 »
Given up sent the regulator back. Paso is shoved to the back of the garage where I cannot see it... :(
I think that any modern reg will require a bit of wiring modification . Paso has a couple of extra wires , one for a voltage sensor ( which can cause excessive charge voltage when the wiring gets a bit tired ) My paso has a honda reg fitted .... not by me but its worked well so far .
I cant remember exactly how a modern reg is wired in but there has been plenty of discussion and tips on the subject , maybe do a search and look in the faq's but dont give up it aint that hard when you know how . :)
Witzie
Post by Witzie »
I use a shindengen fh012aa regulator, I have only connected the 2 pink from the generator and the red/black and the black wire to the battery. It has been running great for a year now. Down side is you will loose the charge dash light.
Kawasaki Z700 1987, Kawasaki ZL1000 1990, Ducati PASO 750 1990, Ducati 900ss 1994,
Kawasaki ZZR1100 1993, Ducati Paso 906 1989
small led voltage meters are a cheap and easy fix.
yosemite
Post by yosemite »
higgy wrote: ↑Mon Aug 29, 2022 10:32 am small led voltage meters are a cheap and easy fix.
I used a charge warning light on mine wrhen I changed the regulator./ Rectifier
https://www.google.com/search?q=improvi ... s-wiz-serp
No problems and working well so far, fitted the unit in place of original bulb and retained with a spot of silicon
manx57
Post by manx57 »
Witzie wrote: ↑Mon Aug 29, 2022 9:29 am I use a shindengen fh012aa regulator, I have only connected the 2 pink from the generator and the red/black and the black wire to the battery. It has been running great for a year now. Down side is you will loose the charge dash light.
I gave up with the regulator I had and returned it and bought one which has the same black connector as mine.
Now I have no spark at all, which is strange as before the reg failed it was running well.
I sent the ECU away to Carmo for test which came back with no faults found! I have 12v at the ECU and at the coils, also the sensor test is 720 ohms but no spark.
Where do I go from here lol
yosemite
Post by yosemite »
Sorry for late reply. I think the coils are normally live when ignition is on ie they have 12volts supplied from the ignition switch , the signal side is tthe earth through the ignition module so if the ecu earth connection is not good or non existent then that could be the cause of your problems
Also if voltage to the ecu drops below about 9v the unit wont work ......properly.
It only takes one dodgy connection in the circuit from battery to coil , and it does a couple of laps round the bike gettin there.
The coils are 0.3ohm , I thought it was a misprint but they are def 0.3ohm....not 3.0, and the coils are powered direct from ignition 12v and the earths are switched , as mentioned above . Hth
JWilliam
Post by JWilliam »
The Paso charge system is a funny one. The 2 pink wires are AC and must be rectified. The red wire from the 'alternator' is 12v and goes to the charge circuit. The 12v output from the rectifier goes to the coil feed. I can pull my Paso panels off and double check this but when I used the Energis rectifier it always gave trouble until I swapped for a Kawasaki unit. The igniton coils are hopeless inefficient and a good swap is for Aprilia with an impedance of 3.5 Ohm improving run characteristics and charge for the Paso.
JWilliam
Post by JWilliam »
I have a Kawasaki rectifier here and I'll explain the wiring connections. First, the red wire from the alternator is 12v and although this could be used for power I found this was heating the lead from the alternator (not good) so I've connected it to the blue from the instrument panel and this is now the charge light feed. The pink wires from the alternator are rectified. The red/black is battery charge, the brown/black is regulator output and this goes to the coil feed. Black wire is 0v earth.
The battery never overcharges and the electrolyte level rarely has to be topped up, unlike with the standard energis rectifier which needed this every other week. On top of that I've got a charge indicator, it works because the instrument light has a 12v feed and if the alternator is stopped the current will flow thru the windings back to earth (eventually). When the alternator is energised the red wire has a 12v output and opposes current flow from the blue wire - warning light goes out.
I note the subject Paso has 2 yellow, red, green wires. I am not familiar with this I advise you check the source of these wires before connecting anything at all.
