Clutch Groan and Noise?
Hi, anyone experienced noises, a groan and shuddering when pulling away from a stop? What I've seen in the old posts(grease, etc) hasn't helped. There is a detent on the "pin" (part # 38 on Fiche page C3), is there supposed to be a ball bearing in the detent? There isn't one shown in the microfiche, but several bikes I've worked on in the past have had one in a similar location. None of them Ducatis, however...
Thanks Jon, I already did copy the "clutch sequence" from the FAQ and restacked the plates, cleaned them, blew them out w/compressed air after running for a while. I pulled the clutch slave piston, and the pin spins freely in the piston. I tried to pull the pin anyways, but it won't come out. So I repacked the bearing with grease, reassembled and bled the clutch really well.
Noise is still there. My other thought is to pull the slave piston from my spare motor, whose pin does come out. Then, change the bearing and put that one in, see if it helps? Or spring for a new clutch (ouch!)
- Finnpaso
- year: 0
Bearing can be also worn.... Did U check those matal plates between friction plates. Normal colour?, NOT blue(what means U have to trow them away, cause they have been "glaced") and then they touch only some part of them to friction plates :toofar: Those plates MUST be in good condition.... If You have to change hole clutch assembly, go to STM 48 teeth basket with very good package of all plates
That is good choise, if basket "holes" are worn too big and start to make too big that "rattle and hum"
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- jcslocum
If it's the groan when slipping the clutch I doubt messing with the slave will help. This is just like squeeking brakes...in reverse. The friction discs slip and grab against the metal discs. It really a shuuder/judded of very slight slip-grab-slip-grab-slip-grab within the disc stack. It's not (supposed to be) bad for the clutch. It's just annoying!
Thanks Jon, what I've been reading elsewhere confirms what you're saying, that it's most likely the basket tabs having grooves, and the clutch drive plates getting hour-glass shapes! I had this problem with my 900ss, and the final fix was a new clutch. (a Barnett, after the offical Ducati fix didn't fix it) I may try to file the basket and clutch tabs flat again, but that's a short term solution at best.
Anatti, your idea is probably best, replace the 12 tooth with a 48 tooth (more surface area, less load per tab), but that's an expensive solution! More than the whole bike cost me to change over all the parts....
And you're right, it sure is annoying! Trying to drag race granny off the red light, and the clutch grabs, grunt, groan, grunt! and the rpm's fall below 1500, rendering all the performance of a Vespa! Damn do I look cool!
- Finnpaso
- year: 0
I had similar problem in my 907IE and it was fixed with new metal plates and friction plates then. Later, when it was time for new friction plates, i changed to STM 48 teeth system, what i have still and it works very nicely still. Remember, that if U go to STM basket/plates, they promise about 3x living time to plates, but surely "u" can also destroy dry clutch very fastly slipping it !!!! Better put bigger rear sprocket, or smaler to front, that bike comes such easy to drive, that there is NOT ANYKIND need to slip clutch. All Ducatis have too long final gearing !!! This 750 Paso is not worst, but 907 and all ST/SS needs shoreter gearing, about 4 teeth bigger to rear, or one smaler to from....
Anyway, i still think, that U have problem in clutch, not in slave, but surely slave also must have good bearing and U have to keep it away from dust, what is just problem in 750/906, cause slave is in right side, not in left, like 907 have, but also sprocket shit is problem in left, if u dont keep that area clean....
907IE -91 red
907IE -91 red
- Finnpaso
- year: 0
Yes, i have such STM basket, all plates, etc stuff in my 907IE, but i havent checked, is 750 basket sameking, so i cant guarantee, but i FEEL, that it fits also to 750Paso. I know, that it fits to my ST4S also, cause it have totally same clutch, as 907 and ST2 and ST4 have. I have one complete STM system waiting to put it to ST4S, when original clutch plates are enough worn. Also red pressure plate with stainless springs and open CF cover and STM Red cute slave, what i put, when original slave goes broken. Btw, to that STM slave can be bought new inside things, what is impossible to Ducati slaves, so i have heard
Those STM parts are "very nice looking and working bits".....
907IE -91 red
907IE -91 red
- Finnpaso
- year: 0
Mark, 750 Paso and earlier 906 modells have right hand side "integrated slave" to clutch cover with bearing. Later 906 and all 907 and all later Ducatis have left side that "real" slave. So, U cant put STM slave to 750, or early 906.
Here U can see STM slave: http://www.stm.to.it/frameset2gb.htm
907IE -91 red
907IE -91 red
