Centrestand ????
Crumpati
Centrestand ????
Post by Crumpati »
My bike has no centrestand, I assume it was removed to fit the non standard exhaust. Its annoying mucking about with a paddock stand when the little handle is there looking at me symbolizing the way things once were!! I'm thinking of buying a second hand one and fitting it up, maybe have to knock a dent in one of the headers or make up a longer stopper at the expense of clearance. I know all exhausts are different, but the stand removal seems to be reasonably common, so presumably for the same clearance issue? Has anyone retro fitted a stand to their bike? Any issues? I'd rather not buy a stand and then find its an impossibility which then leads to buying new pipes or consigning the stand to a box of spares in my ever cluttered garage!!! :) THanks
Crumpati
Re: Centrestand ????
Post by Crumpati »
would I be correct in assuming the 750 Paso centrestand is the same as the 907's? thanks
no, side and centerstand of the P750 and 906 are a little bit shorter.
