Brocken float pin support quick fix.
The Paso 906 . The Webber carburettor. Brocken the float pin brace. What the F. The peice fell to the bench. How the hell am I going to fix this.welding is out of the question. Glueing will never work. I treated it like a Brocken arm, wrapped the Brocken peice in fine copper wire until in was completely wrapped up to the pin, then soldered the copper wire ring until it formed a cast around the Brocken post. Worked like a charm.
- Witzie
- year: 1989
Re: Brocken float pin support quick fix.
that sounds like a good fix!
Kawasaki Z700 1987, Kawasaki ZL1000 1990, Ducati PASO 750 1990, Ducati 900ss 1994, Kawasaki ZZR1100 1993, Ducati Paso 906 1989
alumalloy most likely would work as well
