Front cylinder running lean
Kiwi Rider
Post by Kiwi Rider »
Attached is a pic of my plugs. The rear one looks darker in the photo than it actually is. To my mind it is about right but that front plug is white looking.
I've just changed from plugs with a heat range rating of 8 to ones that are 9. The plugs in the photo are the original 8's I put in when I first got the bike.
I have no knowledge of the weber carburetor, is there a main jet for each cylinder or just one for both?
Re: Front cylinder running lean
one for each pot . Do you have the info to ballance carb barrels ? .... bypass screw etc
Kiwi Rider
No I dont. Are you the man on this?
seems to be in the 906 documents folder now
"weber mod and jetting.zip"
Kiwi Rider
higgy wrote: ↑Sun Feb 16, 2025 1:09 pm seems to be in the 906 documents folder now
Cheers for that
Kiwi Rider wrote: ↑Sun Feb 16, 2025 8:47 am No I dont. Are you the man on this?
Yep , I learnt the hard way , but do have a look at the weber mods , and there is a good one on Paso cam timing too . Mine was miles out so I fitted adjustable cam pulleys .
Mr Kiwi, :cool:
Keep it in mind while reading the jetting doc all the settings are derived for a different carb than what comes on the original sport. Most 750 Paso came with 42 mm carb throat and the 906 a 44 mm.
also there are several folks here have done jetting on the sport and can be found by doing a search
Kiwi Rider
higgy wrote: ↑Sun Feb 23, 2025 2:55 pm Mr Kiwi, :cool:
Thank you for that info. The man at weber specialists who serviced my carb said to check my front manifold rubber for leaks first. Makes sense.
:choo: :choo: that is a great idea
Kiwi Rider
Solved: I replaced the manifold gasket and both plugs look the same colour now after a race meeting on the wkd. Its starting better too. The carburation is still far from perfect though. It revs out nicely but transitioning from a maintenance throttle to getting back on the power it surges and fluffs around a bit. Quite a bit actually.
