Ducati Paso 750 complete restoration
Re: Ducati Paso 750 complete restoration
Do we know the weight of the float?
no I do not,perhaps G can chime in.
there are several threads here on the weight of the float. I do have a couple around I could weigh if I can find time to get out to the garage.
Trace down the problem i had. One of the igniters (black box under seat) was outputing only 2V to the coil When in swapped them fault followed the igniter so i ordered new pair. But problem was still there. Than i figure it out it might be the battery. I had some good lithium battery laying around and it looks like voltage regulator and battery BMs were not compatible. So i bought lead battery and now it works.
you need tight control for a lithium so a good mosfet is required I stick with Shindegen FH020AA or better
