Fuel tank fitment
- oilyrover
Fuel tank fitment
Love working on 30+ year old bikes!
This winter I've been working to convert my Paso fairing to 1/4 turn fasteners. The well nuts offer some alignment flexibility and the new fasteners have less. There was always some weird panel fitment and the opening around the headlight never seemed right.
Yesterday I was looking at how the tank sat on the bike and found some interesting welds around the "tower" under the tank that locates it near the steering head. I'd noticed the paint and primer before but didn't look that closely.
There are a couple of odd touch up spots on one of the fairing panels and the front fender. I thought it'd maybe had a tip over or something. Now I think it took a hit on the tank at some point. Frame looks ok, as does the headlight subframe.
- PXL_20240324_204752199.jpg (147.92 KiB) Viewed 17034 times
- PXL_20240324_204811173.jpg (106.94 KiB) Viewed 17034 times
- PXL_20240324_204801594.jpg (125.21 KiB) Viewed 17034 times
- PXL_20240324_204757304.jpg (107.03 KiB) Viewed 17034 times
1978 SR500
1978 R80/7
1983 R100
1987 750 Paso
1988 GSX-R1100
2004 KTM 625 SXC
1978 SR500
1978 R80/7
1983 R100
1987 750 Paso
1988 GSX-R1100
2004 KTM 625 SXC
Re: Fuel tank fitment
tanks are prone to cracking in that area. Have had my 906 tank welded more than once. Tanks need to be thoroughly washed out and filled with argone before even attempting to weld BTW !
Mine too , I cut the mount right off , beat into shape and welded in a bit of 1/8th steel plate about 4 inches square ( cant remember exactly what size it was ) , trimmed the 1/8th off the mount and welded it back on . The whole weight of the fairing and 1/2 the tank hangs offa that mount.
- oilyrover
How do you manage to get the positioning right?
This one isn't off by much but there are wear marks on fairing panels due to it being off by a little bit.
I wondered if the two threaded bits on the underside were from the factory to locate the mount.
1978 SR500
1978 R80/7
1983 R100
1987 750 Paso
1988 GSX-R1100
2004 KTM 625 SXC
1978 SR500
1978 R80/7
1983 R100
1987 750 Paso
1988 GSX-R1100
2004 KTM 625 SXC
To get the position right Id probly mock the whole thing up ( with headlight fitted )with the tank just sitting on the mount and get everything sitting as you want it and then tack it with a mig welder .
When I did mine I didnt bother fixing the cracks ,I just welded right round the edge of the patch . The idea of the 1/8th" /3mm thick patch was to spread the load over a larger area than just the diameter of the mount/tank weld . I gotta move this bike soon and it sorta in bits so I could probly get a pic if you want .
- oilyrover
At long last an update on the Paso and tank.
I picked up one of those "NOS" 750 tanks that are floating around on the internet. Upon arrival I noticed that the petcock fitting is on the wrong side and the fuel filler is the larger later style.
Since it fit properly on the bike and aligned with the body panels we decided to relocate the petcock to the correct side and then cut the filler out of my original tank and weld it into the new tank.
Many months passed getting that work done and getting into the schedule of the painter. That said, it should be ready for me to pick up next week.
- IMG_20260116_122718.jpg (112.83 KiB) Viewed 602 times
- IMG_20260116_122655.jpg (74.63 KiB) Viewed 602 times
- IMG_20260116_122651.jpg (50.02 KiB) Viewed 602 times
- IMG_20260116_122639.jpg (132.9 KiB) Viewed 602 times
1978 SR500
1978 R80/7
1983 R100
1987 750 Paso
1988 GSX-R1100
2004 KTM 625 SXC
1978 SR500
1978 R80/7
1983 R100
1987 750 Paso
1988 GSX-R1100
2004 KTM 625 SXC
- Janky59
Beautiful work Oily, is that the finished pieces in the 1st pic? Wow, that’s looking good.
Current moto stable:
‘21 Beta 390RS
‘18 BMW R1200RT
‘92 Ducati 907ie
‘21 Beta 390RS
‘18 BMW R1200RT
‘92 Ducati 907ie
- oilyrover
Almost done. That's in clear but before wet sand and buff.
He takes a while but does gorgeous work.
- 8826759813470223012.jpg (110.21 KiB) Viewed 374 times
- 6194746304544485134.jpg (63.9 KiB) Viewed 374 times
- 4584591747955454395.jpg (141.99 KiB) Viewed 374 times
- 7581010362047631184.jpg (173.7 KiB) Viewed 374 times
1978 SR500
1978 R80/7
1983 R100
1987 750 Paso
1988 GSX-R1100
2004 KTM 625 SXC
1978 SR500
1978 R80/7
1983 R100
1987 750 Paso
1988 GSX-R1100
2004 KTM 625 SXC
- oilyrover
for reference, here are pictures of both tanks. and a correction, the fabricator had a new insert laser cut to take the stock filler assembly and welded it into the new tank.
- 4469717389397652889.jpg (69.58 KiB) Viewed 374 times
- 2780570725637738760.jpg (85.57 KiB) Viewed 374 times
- 2723444552297187043.jpg (106.08 KiB) Viewed 374 times
- 1483305295191539589.jpg (123.58 KiB) Viewed 374 times
1978 SR500
1978 R80/7
1983 R100
1987 750 Paso
1988 GSX-R1100
2004 KTM 625 SXC
1978 SR500
1978 R80/7
1983 R100
1987 750 Paso
1988 GSX-R1100
2004 KTM 625 SXC
Nice job!
Is the freshly painted tank the "NOS" 750 tanks? Asking because that is a 907IE tank, which is why the connections are different and there's a bracket for the electric fuel pump inside.
The seat lock is upside down.
