Wanted: Paso Kick Stand Switch
Pasop750
Post by Pasop750 »
Mine stopped working (dash light would not come on with kickstand down). Ducati Part # 037012590 is unobtainium. Let me know if you can help me out.
Many thanks!
Re: Wanted: Paso Kick Stand Switch
This is where one needs to keep his eyes peeled when in motorbike shops .....lookin for modern bits that might fit offa new bikes .....they all have a side stand switch .....maybe one could be fitted to Paso . In any event make sure its the switch and not the bulb or wiring .😁
:beer: :phone: ditto on the bulb and wiring especially where the dash connectors are concerned
Post by Tamburinifan »
+1 on wiring.
Pasop750
Post by Pasop750 »
Thanks for the suggestions! I have checked the wiring and the dash light and they are both working. I removed the switch and bench tested it and it is definitely the problem. Unfortunately the switch is a sealed unit (which I found out when attempting to dismantle it) and now it's beyond repair.
Pasop750 wrote: ↑Mon Feb 02, 2026 12:58 pm Thanks for the suggestions! I have checked the wiring and the dash light and they are both working. I removed the switch and bench tested it and it is definitely the problem. Unfortunately the switch is a sealed unit (which I found out when attempting to dismantle it) and now it's beyond repair.
Ha ha ,often the best way to diagnose problems ....pull it to bits ......well ya gotta be sure😁
Have a google ,I found some on ebay (used) and new from a couple of places. Google sidestand switch tho , not kickstand
Pasop750
Post by Pasop750 »
So a couple of things to update this thread:
1. I found this on Amazon
https://www.amazon.com/dp/B0DF2TP7SQ?re ... asin_title
The stock threads for the OEM kickstand switch are M8 x 1.00 pitch. This switch is M7 x 0.75 so I had to "MacGyver" the mounting (no threads were damaged).
2. In the meantime I managed to fix the broken stock switch so now I have a spare
Bottom line is I am not looking for a stock switch any more!
:thumbup:
