I'm giving my Paso 87 a full Maintenance Service. However I
noticed i have a leak next to the spark plug of the vertical
cylinder. A few centimeters to the right of the spark plug
is a small screw. At this screw i have an oil leak. I noticed
that the horizontal cylinder has the same screw next to the
spark plug.
What's the use of this screw ? Can't find the answer in the
manual. Somehow the screw has to block the oil of coming
out of the cylinder. :thumbdown:
The nasty thing is that the screw is so thightly that i can't get
it loose. I sprayed some creaping oil (WD-40) on it.
Creaping Oil, is that english ?
Is there at the end of the screw a contra-nut perhaps ?
Does anybody know ? Do I have to dismantle the upper cylinderhead before i can loosen the screw. :screwy:
This must be a leak that other paso drivers have had.
greetz,
Steven
