power loss
power loss
Engine starts fine and runs for about 20 min, no problem. It then backfires a few times and looses power. If I let it sit it starts fine and runs for about 20 min. Any thoughts would be appreciated.
spark plugs are clean, fuel filter is not clogged (the one of the petcock also), valve clearance is ok, carbs synched and the rubbers of the inlet manifolds ok ?
This would be the first things I would check. As the issue does not appear from the start it could be that something cloggs and the engine does not get enough fuel, but as there`s backfiring it might have to do with the engine/carbs and all other parts getting warm. This could speak for some airleak. Check if everything from the airfilterbox down to the manifold/cylinder is tightened well and take a closer look at the rubber parts.
Gerhard
Gerhard
thinking of it, if it loses power it seems that one cylinder drops out. Usually the front one (for whatever reason). Do you have a spark ? Do you have problems with your battery (regulator) lately ?
If it looses power after some time and you open throttle, does the power come back (and the sound) ? (sorry a stupid question, but some people cannot "hear" if an engine is running on both or only on one cylinder)
- ducapaso
Have a look to the ignition wiring (both low and high voltage) a loss of this kind can also happen because of an ignition coil failure (in the downloads you'll find how to test them)
I think this sould not be a fuel trouble, as the engine just "shut" when the fuel is off.
In the very next minutes after starting, the engine is powerful in 5 gear or it looses power over 6000 rpm ? this is tipical for spark plugs gone
i'm waiting for your reply...
ex...Red "smooth" 753349
what is the filter at the petcock?
is there another filter? I replaced the one before the fuel pump, thought it was the culprit. all else is ok, no problems with battery or rubber.
Sounds like a classic fuel starvation problem. Possibly a kinked fuel line?
The next time it loses power, try opening the gas cap and see if that makes a difference. Sometimes the tank will cause a vacuum and starve the engine of fuel. Does anyone know where the air inlet is on a Paso? Probably in the cap.
If it does it at idle, try pulling the tank, and make an auxiliary fuel tank ( a mustard bottle and some fuel line works great!), hang it up high, and bypass the fuel pump. This will eliminate the fuel pump; if the problem doesn't reappear, it's the pump.
I know nothing of repairing the pump, I eliminated mine and it works fine without it.
- ducapaso
there's a small metal tube insede the tank (you can see it spoiling under the tank or opening the cap: it runs across the tank to its upper part) and this provides to air pressure balancing inside the tank... Maybe the engine can run also without fuel pump, bypassing it... I never tryed to do, but it should require a full tank.
