To refresh...bike had been running fine. Then with the key in the on position I can hear a faint ticking noise, accompanied by a flicker in the lights on the panel. This ticking is fast and continuous. After starting, the bike will not run correctly, it runs poorly under load and will not idle correctly.
Ok, after further investigation and removal of body panels, the clicking sound with the key in the "on" position is coming from the small black box where the wires connect to the bottom of the fuel pump. Keep in mind the bike still starts, just runs poorly and will not idle.
If anyone can tell me what part this is, or how to fix it, please respond. If I take the 2 screws out of the small black unit, anything to be careful of?
I appreciate any help the experts can give me.
Mike (lucky duc)
