can anyone help me with a reason why i get an occasionsal back fire in the carbs or is this a common occurance with these carbs
thanks
Rodney
They're actually an automotive carb, if that makes a slight difference? (Anyone?) IMO, I think they'd be better off on a farm tractor ... :neener:motiztab wrote:What gets me is why do these carbs go off tune?
How do you actually take this measurement? Do you gravity feed some fuel down the pipe with the carb intact and then remove the top of the carb with the float and make the measurement of the fuel left in the empty bowl.jfiore wrote: First, you need to change your idle jets to .060 size. Then you need to set your float height to 46 mm from the gasket surface of the carb cover. This will require removing the airbox, the air intakes, and the carb cover.
