Any idea what petrol is made of these days? Most (not all!) objects that are petrol resistant will be thinner resistant as well. However check the outside parts of the pump mounting etc. My fuel pump is not submerged since it is mounted on the outside.
The effect thinner has on the insulation of the wires I use to hook it up to a battery to is quite interesting by the way. Still have to get some fuel resistant wires. Does anyone know what I can use for that? Also to replace level sender wiring in the tank?
Michiel
