paso 750 valve job
paso 750 valve job
well, i am about one week away from owning a paso, and according to the previous owner it is due for new valve shims. I was hoping someone could help me procure some step by step instructions on how to perform said procedure. any and all help is welcomed and appreciated!
download the Haynes manual. You find all you need there.
otherwise there`s:
http://www.buschandbusch.com/ducatisuite/valves.html
http://www.geocities.com/MotorCity/track/2228/desmo.htm
(unluckily the last page is missing)
http://www.ducatitech.com/2v/maint/adjust/index.html
You`ll find the correct valve clearances in the workshop manual.
Gerhard
otherwise there`s:
Gerhard
- persempre907
no matter you could download also the Haynes manual
http://forums.ducatipaso.org/viewtopic. ... tit&lid=17
