Dual bulb headlight?
Rlbol
year: 0
Post by Rlbol »
I recently saw one on Ebay. The item description said it would fit an paso/907. Does anyone know anything about this? It looked like the normal square head light but had 2 H4 bulbs?
ducapaso
Post by ducapaso »
Mike "the keeper of this madness" has posted something about this... search in the classified posting
Finnpaso
year: 0
Post by Finnpaso »
I have put to both my Pasos dual round headlights with 2 X H4 bulbs, but i dont have fotos in Gallery yet.
907IE -91 red/metal grey
907IE -91 red
jcslocum
Post by jcslocum »
It's supposed to be a better lens with better light on the road.
redpaso
Post by redpaso »
THE US spec Yamaha FZ-750 (1987) used the same headlight casing but with dual headlights inside. Apparently they slot in no mods needed. This is something I plan doing after some brake upgrades. These were still available new from Yamaha approximately 12 months ago.
Here is a picture of Pope's Dual Headlight Paso.
Redpaso
Rlbol
year: 0
Post by Rlbol »
Thanks everyone I will try and find one.
What is the deal with the mesh below the headlight?
jcslocum
Post by jcslocum »
You should have the mesh on yours.
I stand corrected!
KillerB
Post by KillerB »
907 Pasos are mesh free.
Regards, B
persempre907
Post by persempre907 »
Are the Yamaha FZ 750 EU headlight different from the US spec? No matter, it would have work better than the OEM unit, I guess.
Finnpaso
year: 0
Post by Finnpaso »
I agree You Jon, 907IE is MESHfree Ducati !!! :funny:
907IE -91 red
Stingray230SX
Post by Stingray230SX »
that kind of updates the look a little as well!!
i think that the headlight on the paso is the only thing on it that "dates' it as an older bike
probably best to go ahead and do the relay and power the light directly from the battery when putting in this new dual bulb assembly, correct?
anybody got a part number for this lens assembly etc...?
doug(who wants to find one of these,can ya tell)
1992 907ie #1473 Nero SOLD
Finnpaso
year: 0
Post by Finnpaso »
There is ONE bigger problem with Dual H4 headlights: If You use both BULBS TOGETHER, then not enough current from charging system to battery!!!! I have seen this in my 907IE and after 65 kms drive, i have to ask one honda driver to push me with jump start, when i stopped to fuel my bike, so BOTH bulbs cant use same time. 2 X high beam, or 2 X low beam takes TOO MUCH to 907. I KNOW THAT.... Anyway "look" is much better now.... Btw, i put switch to handlebar to dissconnect another bulb and i use ONLY both bulbs , when REALLY NEED and short time then! :evil: That P7 ECU NEEDS enough voltage to function, like should. There is voltage "looking" wire and if voltage drops too low from battery, then ECU cuts off! I know, i know..... :evil: :evil: :evil:
907IE -91 red
Shelboss
Dual Headlamp conversion
Post by Shelboss »
This headlamp assembly is listed as P/N 1LJ-84303-A0-00 on this site and sells for $132.17 plus shipping, best price I've found new.
http://shop.yamaha-motorcycleparts.com/ ... /home.aspx
The models it fits are Yamaha 86 FZ750S, 87 FZ700T & TC, and 88 FZ750U, the R models are different. It comes from Japan and is currently back-ordered.
Shelboss
Dual Headlight
Post by Shelboss »
I just finished testing the power output of my alternator. I used a clamp-on current meter on the alternator wire just ahead of the 30 amp fuse. To test for potential output of the alternator, I ran the headlight without starting for about 10 minutes, then started the bike. Altenator output was 20.4 amps at 14.3 volts, or 292 watts. I imagine with a dead battery it might approach 350 watts as speced. I then let the battery charge up and ran it with the high beam at 3K rpm. It drew 186 watts. I believe there is 100-150 watts to spare on these bikes. The previous owner of my bike ran a heated vest and grips, which add up to 90 watts if constantly on. The wiring to the regulator and alternator have been beefed up and an aftermarket regulator put in, so proceed with caution when adding load, lest you'll be pushing it home :sad:
Shelboss
Dual Headlight power
Post by Shelboss »
The stock bulb for the dual headlights is listed as a 35/35 watt. Is anyone using it with the stock wattage?
