Hi -
Just got my 1991 907 IE back from the shop. The whole thing is restored but they only thing they could not find was the mirror/turn singal units for both sides, which mine are cracked and taped up.
They said the electrical is all fine if I can at worst only find the case.
Any help is appreciated!!!
NEED '91 907IE - Seeking turn signal/mirror units.
- zap
hi, this is zap from the netherlands.
i've got a pair of mirrors from a cagiva freccia (2nd hand in good condition)
they are almost the same. look! the cagiva is the left one.
http://www.geocities.com/750paso/pictur ... irror1.jpg
only one of my mirrors has a little piece off ( 2 by 2 mm.) you can't see it when it is on the bike.
if you are interested, i can send you some pics!
mail to axtrabter@hotmail.com.
i also have got a brand new left side unit from cagiva.
greets, ab.
greets, ab.
I also need the right side mirror. You should try http://www.oldracingspareparts.com They have helped me in the past although they are not cheap and the shipping from Italy is also expensive. Good luck
saw this on ebay
http://cgi.ebay.com/ebaymotors/DUCATI-M ... dZViewItem
also i have the one from my 92 907ie right one is cracked but easily repairable, left one shattered but i have the pieces if you need a project this winter. i have lots of other 907 parts like
headlight, taillight, expansion tank, 17" rims, rectifer, weber computer, stock chip and 907ie fim chip, stock pipes and a set of staintunes with only a ding on left side from a fall down, center stand
