Swingarm Swap
BikerBard
Swingarm Swap
Post by BikerBard »
I'm in the middle of the swingarm swap and I'm cussing the #*$%^&!!! designer of this bike! The service manual says to simply remove the bolt at the bottom of the shock...the bolt holding the connecting rods on the swingarm....and it should simply fall out. HA! they fail to mention that the freaking exhaust pipe runs thru the middle of the thing! I'm giving up for tonight and will finish sometime tomorrow (I hope). Here's hoping none of y'all have to do this anytime soon :thumbdown:
DG
Donna G
'12 Moto Guzzi V7Racer
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
jcslocum
Post by jcslocum »
These bike have character and ....um...build character.
Good luck and don't get too frustrated.
Desmo_Demon
Post by Desmo_Demon »
Ooohhh...great! :eek: Just another thing for me to look forward to with my Paso project, as I am thinking of taking the swingarm off to inspect the bearings, seals, pivot points, and torques....I just don't trust what the previous owner did to the bike. :ugh:
:D
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
Skins
Post by Skins »
:cool:
It's not hard to remove the exhaust system piece by piece. That should make the job a lot easier.
Finnpaso
year: 0
Post by Finnpaso »
I would also go that way... Simple job to take all exhausts pipes away! :thumbup: :D
907IE -91 red/metal grey
907IE -91 red
BikerBard
Post by BikerBard »
got the exhaust off....but the swingarm ain't budging where it's attatched to the frame. I took the swingarm spindle out but nothing I try is working. Anybody been thru this before?
DG
Donna G
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
Skins
Post by Skins »
:cool:
I've had the swingarm spindle out when I've removed the engine, but I've never taken the swingarm off. However, the manual says (under Removal and Overhaul of Swingarm) to put a hydraulic hoist under the engine (I had ropes from a beam coming down to take the weight of the engine), then remove the spindle, then (quote) 'extract complete swing arm with bushings and spacers'.
So, it would seem that with the weight of the engine supported, there should be nothing to stop you pulling off the swing arm once the strap, shock, and spindle have been removed.
jcslocum
Post by jcslocum »
When I had my engine out the swingarm was just flopping there loose. Maybe with the engine still it's pinched inplace? Might need some persuading with the mechanics best friend, the 5 lb. hammer?
BikerBard
Post by BikerBard »
jcslocum wrote:Might need some persuading with the mechanics best friend, the 5 lb. hammer?
hehehe, it finally came out. Just needed to be man-handled. (or should I say...girl handled :D )
The new one is in and I'm fixing to tighten everything back up and get the wheel on. I'll post some pics of the damage when I get a chance.
Thanks to y'all for the advice :)
DG
Donna G
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
Skins
Post by Skins »
:thumbup:
Good stuff!
Now make sure of proper chain tension. Loose is better than tight, for smooth running, and to avoid trouble with the bearing at the front end of the chain. I run mine at about 1" of slack.
ducapaso
Post by ducapaso »
someone told me to seat on the bike and leave about 1/2" slack, in order to have thechain fitted to your size :thumbup:
Skins
Post by Skins »
:cool:
I reckon that's a bit tight, Nicola. I prefer almost 1 inch slack with the suspension half compressed. You need a good bit of slack to absorb engine and transmission vibrations, if you want a really smooth ride.
A good way to compress the suspension is with a loop of heavy rope over the seat and through the wheel, with a towel for padding. I use the rope that controls the main sail on my sail boat, but lots of turns of a lighter rope would do also.
jcslocum
Post by jcslocum »
I do it by sitting on the bike will all of my gear on. The I adjust for 1" (25mm) slack. Loose is always better than tight. I know from experience. 1/2" (12mm) is too tight!
ducapaso
Post by ducapaso »
:D
next time I'll try a looser slacking!
Skins
Post by Skins »
:thumbup:
Good on ya, Nicola! I reckon you can feel the difference in vibration of different tensions when you ride. At low speeds, up to 75 km/h (45 mph) a slacker chain (up to 30mm/ 1.25in) can give you a really smooth ride, but at higher speeds it needs to be tighter, no more than 25mm/1in.
I reckon the chain is the soul of the machine.
