Page 9 of 10
Re: my Paso - a never ending (love) story ...
Posted: Fri Apr 20, 2012 11:20 pm
by scimmione
Hey G - Is that a heated Northern Ultrasonic parts cleaner I see in the top pic?
Posted: Sat Apr 21, 2012 9:20 am
by paso750
nah, that`s just some reasonable priced thing made somewhere in Asia. It says DailyMag on it. Works ok though. (It is heated, non heated didn`t make sense for me)
Posted: Sun Apr 22, 2012 5:07 pm
by WolfManSpecial
Hello.just discovered yours post
incredible work
lots of ideas for me
thanks
Posted: Sun Jul 14, 2013 9:52 am
by paso750
if anyone is interested, the crankcase breather of later Ducatis can be fitted on a Pantah motor.
This only requires shortening the hose by 1,5-1,8mm.
I have to point out though that I don`t have the original cylinders on my engine so I`m not 100% sure if the original cylinders with their wider cooling fins have the same large cutout for the later type crankcase breather. (but as the cylinder heads do, the cylinders should as well)
The original part of the P750, Sport, 906 is just a hose connector.
The later breathers have a reed valve in them, aftermarket parts do as well, but not all.
It`s the same used on:
Ducati Monster 600-1000 inkl S2R, S4
Ducati 748/916/996/998/999
Ducati 750/900/1000 SS/ie
Ducati 851/888
Ducati 907 I.E. `92
Ducati Hypermotard 1100
Ducati MH 900 evo
Ducati Multistrada 1000 DS
Ducati ST2/ ST3/ ST4 S
Posted: Sun Jul 14, 2013 4:41 pm
by higgy
This is very interesting, i think the 907 tank is shaped even different.... i have to check that...
The 907 tank is different. It also has a plate that the front mount is mounted on so they do not crack like the tanks on the 750 and 906
Posted: Mon Jul 15, 2013 10:22 am
by 907pasonut
that front tank mount is supporting a bit of weight and only has a few spot welds to hold it together, I've added some metal bonding glue around the base to strenghen it a bit.
this post has now had 9596 hits...must be some sort of record...good on ya G!
...and I actually bought that sump breather, its good for both 907/851
Posted: Sat Sep 28, 2013 11:03 am
by paso750
Posted: Sat Sep 28, 2013 10:36 pm
by Tamburinifan
Interesting as always.
I always thought the chain guard looks dull.
Keep the mould! If you consider doing more of them,
I`ll gladly buy one.
Posted: Sun Sep 29, 2013 1:55 am
by koko64
What Elefant parts are you making?
Posted: Sun Sep 29, 2013 8:05 am
by paso750
Gert, if I make another (and I actually didn´t plan to make more than one) it`ll probably be only next year.
Tony, the parts on the last pic. At least I`m trying. The license plate holder is a bit complex so `ll have to see if I manage to copy it.
Posted: Mon Sep 30, 2013 12:36 pm
by Tamburinifan
No worries, G, I`m in no hurry bout this.
Posted: Sat Apr 19, 2014 9:49 am
by paso750
After the
taillight mod and the
instrument panel LED conversion there was one more thing to do.
Long time ago I had damaged a brandnew instrument panel frame when trying to drill a hole into it
I was thinking a while about ways to save that part and the most reasonable seems to take advantage of this situation and implement a miniature voltmeter which at least is useful.
Those things are cheap being delivered directly from China with free shipping. To have the choice I ordered them in red, yellow, green and blue illumination. The first order didn`t arrive after 8 weeks so I bought some others. To my surprise when the second set arrived a few days later the first ordered ones arrived as well.
Although the dimensions according to the auctions were the same the second set is even smaller than the first so finding a place for them is no problem. One could also fit them on the bottom left or right of the instrument panel or next to the clock.
The cut out needs to become as perfect as possible to minimize any visbile gap. Everything white incl the voltmeters were later painted flat black. Although they are almost press fit black sealant will secure them and prevent any backlight to shine through around the voltmeter.
The mounting wings don`t stand over but will be removed anyway. The depth of the voltmeter is not a problem. Both types I got can be mounted flush w/o touching the faceplate of the gauges. (the protection foil is still on)
first test
Trying all voltmeters
The smaller ones
Red is a no-go. It`s like a warning light. Yellow is my current favourite (in combination with the white LEDs used for the instrument panel illumination). Green or blue are not bad but have a strong glow.
Guess I`ll have to try outside the house to get a better picture ...
I got the very small ones from this seller (have rarely seen an asian seller with so little negative feedback)
http://www.ebay.com/sch/m.html?_odkw=&i ... &_from=R40
The front plate is 23x10mm while others like the ones I ordered first are 23x14mm (display width x height).
Some voltmeters exist as two or three wire versions. The three wire versions have a wider measuring range i.e. 0-100V while the two wire versions are i.e. 3-30V so for a bike it`s irrelevant which ones to chose.
There exist also waterproof voltmeters which could be fitted in the metal bracket below the instrument panel or in the fairing and other for a cigarette lighter (remove the plug and connect it wherever you want).
edit: I ended up going with the red voltmeter as that`s the only one which was readable in direct sunlight.
Posted: Mon Jun 08, 2015 10:47 pm
by MarkST
What a fantastic bike, and well done on all the work you've done on it. I've thoroughly enjoyed reading through this thread.
Posted: Sat Aug 01, 2015 2:27 pm
by paso750
Posted: Sat Aug 01, 2015 3:54 pm
by paso750
Francesco commented on the clutch cover years ago so it finally got powdercoated. (happy now?
) The polished vented clutch cover didn`t match the rest of the bike so it got powdercoated black as well.
The foam plug used to protect the cylinder melted to it in the oven
Scratching out all the crust with a wooden stick was the evening job while watching the telly. The edges of the powder coat could be removed with an old scalpell. After it was clean again the cylinder was sanded with 2000 grit wet sanding paper and then polished with Autosol and the drill.
It`s interesting btw that even after a few years of being unused there would be some dirt in the cylinder and some surface rust on the clutch piston.
As a gift I got a little Sigma computer. There isn`t really a place to mount it so a hole was drilled into the handlebar to fixate it with its O ring.
coffee break ...
