Page 2 of 3
Posted: Mon Jun 25, 2007 3:45 pm
by Tamburinifan
Antti,
have you weighted the old flywheel?
dyno`d after mods? Guess you`re +90Hp... :thumbup:
Posted: Mon Jun 25, 2007 4:39 pm
by Finnpaso
Yes, from old flywheel.... :evil: Some small job needs still, but end of this summer i dynoed it and then i can tell more about torque/power. :thumbup:
Posted: Sat Nov 03, 2007 12:56 pm
by Tamburinifan
Do ST2 heads fit on a 907 engine?
Posted: Sat Nov 03, 2007 9:24 pm
by Finnpaso
Surely they fit very easily, no anykind troubles.... And they are much better quality, than original 907 heads.... If You find such "cheaply", buy them immediatelly. Most of performance come from ST2 cams!!!! :evil:
Posted: Sun Nov 04, 2007 1:39 am
by Tamburinifan
Thx, Antti! :thumbup:
Posted: Sun Nov 04, 2007 2:39 pm
by ducbertus
I bought a ST2 engine to build in my 907.
payed just € 400 for it. This is cheaper as a set of drop-in pistons and cams.
The ST2 is probably the best single spark engine.
casings ST2 are same as the 907.
problem is the electronics.
talked about this with my dealer.
I will change the wiring partly to use a newer 900SSie M16 computer, which has a programmable Eprom and use the only sensor as mouted in the ST2.
Posted: Sun Nov 04, 2007 8:11 pm
by Finnpaso
400€ was good deal, if it was running engine. :thumbup: You have to modifie electrics alot, cause ST2 have only one pick up and P7 have 2. That is not only thing, but anyway i wish good luck to You. :thumbup:
Posted: Sun Nov 04, 2007 9:21 pm
by ducbertus
I spotted the engine on Ebay during my holyday in the USA.
The company I work for has also a unit in the States. Sometimes we receive return-shipments from them. on one of these shipments my engine will come to the Netherlands
I didn't see her running.
but was able to inspect the engine throughly.
All gears are working, easy to cranck, with plugs in good compression. belts ok. clutch ok. I removed valvecover to see inside the enging. Sofar is everything OK.
Re: Engine swap?
Posted: Sat Nov 17, 2007 11:01 am
by Tamburinifan
WRONG INFO! :evil:
No output for mecanichal tach on ST2 heads.... :(
Secondhand ST2heads anyone? :roll:
Re: Engine swap?
Posted: Sat Nov 17, 2007 12:32 pm
by Finnpaso
U are right, Gert, i didnt remember, that ST2 have electrical tacho, but other way they should fit easily... :D
Re: Engine swap?
Posted: Sat Nov 17, 2007 1:17 pm
by Tamburinifan
Who`s interested in switching the instrument panel on a Paso? :roll:
So, ST2 heads DO NOT FIT a 907. Period. :x :evil:
Re: Engine swap?
Posted: Sat Nov 17, 2007 6:33 pm
by Finnpaso
I think, very easy to find electrical tachos from internet shops.... Maybe much better quality also then.... :P
Re: Engine swap?
Posted: Sat Nov 17, 2007 6:53 pm
by ducbertus
The ST2 horizontal head still has the boss which holds the mechanical tachodrive.
So, with a little bit of machining it must possible to mount the orginal tachodrive.
The opposit is what antti suggested, to move to electrical tacho's.
on http://www.wmd-instrumente.de/ you can find very nice combinations of Tacho and Spedo in one casing. Very nice, but expensive.
As I still are swap my ST2 engine in the 907, has anyone experience with a 907/ST2 converted to dual spark.
I done this trick on aircooled engines several times.
Ducbertus
Re: Engine swap?
Posted: Sat Nov 17, 2007 7:29 pm
by Finnpaso
2 years ago i planned that to 907 heads, but remembering, that there is some water line just in place, where that another spark plug thread would be. 900ss engine dont have that water line, so it can be done to 900ss heads. One of my Ducati friend had such mod in very early 900 belt engine. I think, just same thing with ST heads, as 907 heads...
Re: Engine swap?
Posted: Sat Nov 17, 2007 7:45 pm
by Tamburinifan
I can buy gauges, I can buy a new motor or even a new bike.
That`s not the point, this is:
They don`t.
