Page 2 of 3
Re: Oil leak near exhaustpipe
Posted: Sat Aug 29, 2009 2:58 pm
by persempre907
higgy wrote:Any time you take off a head it is a good idea to check the head and the cylinder to be sure it is true. A good straight edge only cost between 20 and 30 dollars(USD) in the size required.Feeler gauges are also relatively cheap as well. Also like stated earlier in this thread don't forget the o-rings under the cylinder.
If you do find you head is warped it is a much better idea to straighten it first and only as a last resort should you have it resurfaced. If the surface is out of true,then the cam bores are also out of alignment and this is much more critical than the gasket surface. Broken timing belts are much worse than any annoying oil or coolant leak. :thumbup: Straightening a head is a little more involved
(meaning more money) than machining but not difficult. You do need a steel plate that is true(flat= big dinero :( ) and large enough to take the strain of torquing the head to it and heating the whole assembly in an oven to 425F(218C) then letting it cool slowly and rechecking it for trueness and repeating the process till it is true By the way you don't want to do this in any oven that is used for cooking :lol:
Hope this helps and just let me know if you need more detailed info
Many thanks for your explanation, even if that is too far from my skills :oops: :oops: :oops: :oops: ...
I'd be happy if I'd manage to take the heads apart and bring to rectify them.
Posted: Sat Aug 29, 2009 8:13 pm
by Tamburinifan
I measured my head-to-cyl gap in 3-4 places, it was 0.35mm all around both.
Torqued my heads to right Nm i 3 stages as recommended.
I still don`t understand how/why these leaks occur?!? :?
Could there be miniscule cracks?
Posted: Sun Aug 30, 2009 2:12 pm
by higgy
Even Viton over time looses its elasticity and becomes brittle and hard. Some of the additives in oil and coolant are capable of forming layers that are one molecule thick.Over time and repeated cycles of heating and cooling the viton looses its seal and allows these monolayers to seep into these small gaps making them larger and larger. Once the fluid has made it past the sealing area hydraulic action takes over making the leak bigger and bigger. Most times the first indication of a leak is a small accumulation of dirt around the seal.
Here are some pictures of common failures in Viton seals. Hope this helps you understand :thumbup:
Image Chemical failure
Image O-ring too big
Image sealing surfaces not clean
Image Viton not cured properly
Image Excess Out gassing
Image Over torquing
Image Over heat/repeated heat cycles
Posted: Sun Aug 30, 2009 2:30 pm
by Tamburinifan
Very educating, higgy, thx! :thumbup:
Posted: Sun Sep 13, 2009 9:02 am
by jomo
I don't know what to do as I replaced the "o" rings about 10,000 km back and they leaked within a few thousand kilometres. Because it didn't leak until 20,000km one must assume the metal parts have changed shape because new "green' "o" rings didn't fix the problem.
Posted: Sun Sep 13, 2009 3:44 pm
by higgy
you will need to have the head and cylinder checked with a straight edge. Also everything has to be clean and dry on assembly. Soap and water are the only acceptable cleaning agents for final prep. soap and water and air dry. No carb cleaner, no brake clean, no solvents at all.Good old soap and water, same stuff used to do your dishes.
Posted: Mon Sep 14, 2009 3:04 am
by Duc906
(meaning more money) than machining but not difficult. You do need a steel plate that is true(flat= big dinero :( ) and large enough to take the strain of torquing the head to it and heating the whole assembly in an oven to 425F(218C) then letting it cool slowly and rechecking it for trueness and repeating the process till it is true.Hope this helps and just let me know if you need more detailed info
I've had to deal with this problem recently and I must say that Higgy's method for straightening the head works quite well.Thanks Higgy. :thumbup: I used a piece of 30mm plate,that I ground flat,to bolt the head to.I had to heat it up twice to get it near flat.To make sure the head was going to mate to the bore propperly I machined up a lapping block and lapped the surface on the head.
higgy wrote:By the way you don't want to do this in any oven that is used for cooking :lol:
Yep,It upsets the wife. :lol:
Posted: Thu Oct 08, 2009 1:03 am
by du907
I too had the oil leak at the heads on my 907. I took the heads off and replaced the o-rings with OEM rings, 5 TIMES!!!!!! I even took the bike to two different dealers and paid good money to them and they couldn't stop the leakage. I then tried o-rings that had the same diameter on the inside and outside but where thicker. That didn't help either. I have 52,000 miles on my bike. I had the engine rebuilt last year and the Ducshop which built all the engines for the Ducati racing team here in the US did the work. They said that there was not that much pressure at these passages. They also said that when they did my engine that they fix the leaks. Well, it still leaks, just no where near as bad. I guess you could say they get "wet". Wipe your had down there and you will have oil on it.
By the way, I never replaced the base gaskets at the bottom of the cylinders a single time and they never leaked.
Posted: Thu Oct 08, 2009 1:59 pm
by Tamburinifan
They put liquid gasket around the Orings, is that what almost cured it?
Did they do anthing more?
Posted: Sun Nov 15, 2009 10:08 am
by jomo
I think we all agree. That's the way it is!
Posted: Sun Nov 15, 2009 3:12 pm
by higgy
Years ago,when I worked for Maserati,we used some very expensive Anaerobic Adhesives and Anaerobic Sealants on every o-ring and most gaskets. Just a very very light coating.
Worked very well when applied properly. Might solve the issue here. Getting the right amount was very tricky but other than that and the expense they are easy to work with as they don't harden
in the presence of air so you have all the time you need to work with them.
Posted: Tue Dec 01, 2009 12:58 am
by du907
I have a 1992 907IE. I have taken the heads off at least 5 times my shelf to fix the oil leak and it never helped. I had 3 different dealers attempt it too, but they couldn't stop the leak. My I make a suggestion.
When you replace the o-rings and are putting the heads back on, you will find that you cannot get a socket on the head nuts. Also, remove the frame bolts that attach to the cylinders before torquing the heads, then replace them after torquing the heads. If you make a wrench like the special tool that Ducati suggests (take a combination wrench, with both an open end and a box end, and weld a socket to the middle so that you can attach a torque wrench) you will still need to find a torque converter table(list) in order to get the proper torque on the head nuts. In other words there are conversion tables that use the distance from the nut to the attachment point of the wrench and the angle the torque wrench is to the tool. Using this conversion table will help you get the proper torque on the head nuts. I think this was always my problem because I don't think I ever got the head nuts to the proper torque using the homemade wrench and a torque wrench at 90 degree angle. With the engine still in the frame, to torque the head bolts you will have to work around the frame so getting the proper torque is not easy.
I don't know where to obtain the conversion tables.
du907
du
Posted: Tue Dec 01, 2009 9:20 am
by Duc906
When I rebuilt my 906 recently I made up a tool similar to the one for the ST2,then I used the torque
settings for a ST2.
Posted: Tue Dec 01, 2009 8:49 pm
by persempre907
Do you have some leaks anymore?
So, could it be enough to re-torque the leaking head?
Posted: Fri Dec 04, 2009 6:08 am
by ducapaso
It's quite an hazard loose&retorque an old gasket!
