Page 2 of 2
Re: MotoLectric Starter Cable upgrade - what a difference!
Posted: Sun Jun 12, 2011 3:37 am
by higgy
Dekka is a glass mat type battery, no gel
All AGM batteries have enhancements over flooded lead acid batteries:
Purer lead in the plates, as each plate no longer needs to support its own weight, due to the sandwich construction with AGM matting. Traditional cells must support their own weight in the bath of acid.
Fluid retention - un-spillable
High specific power or power density, holding roughly 1.5x the AH capacity of flooded batteries due to purer lead[citation needed]
Low internal resistance allowing them to be charged and discharged quite rapidly
Water conservation - never requires addition of water
Acid encapsulation in the matting
Operation well below 0°F or -18 °C.
Availability of UL, DOT, CE, Coast Guard, and Mil-Spec approved types
Vibration resistance due to the sandwich construction.
[edit] Disadvantages
Cost. AGM automobile batteries for example, are typically about twice the price of flooded-cell batteries in a given BCI size group.
AGM batteries have up to a 10 year lifespan. For an AGM battery, the depth of discharge for optimal performance is up to 80% but flooded batteries can only be rated up to 50% depth of discharge.
AGM batteries do not tolerate overcharging. Overcharging dissociates the water in the electrolyte, which is unable to be replaced, leading to premature failure.
Posted: Sun Jun 12, 2011 8:15 am
by paso750
Deka is a battery manufacturer
http://www.dekabatteries.com/
Posted: Sun Jun 19, 2011 2:36 pm
by 907pasonut
just a short note re my AGM battery, I left it without trickle charging for 8 weeks (clock on) did go for a couple of short rides in between this time, today it did hesitate to start...but started whithin 3-4 seconds, I still think its a great battery, but from now on I will charge it once every one or two weeks :thumbup:
Posted: Sun Jun 19, 2011 3:58 pm
by wup
does anyone know if motolectric is still in business? I can not get a reply!!
Posted: Mon Jun 20, 2011 10:38 am
by higgy
just sent an email to mike,I;ll lt you know when I her from him,he has had issues with his mail server in the past :thumbup:
Posted: Mon Jun 20, 2011 10:53 am
by Harry
I dealt with Mike about ten days ago and yes he has had some e mail issues but he is very good to deal with and i look forward to my Motolectric Kit to arrive in WA
