Page 2 of 12
Re: Rebuilding my 907 ST3
Posted: Sat Mar 12, 2011 6:29 pm
Pics of the strengthed motor mounts would be nice.
Note the engine is mounted in the frame without the front engine mounts.
Posted: Sat Mar 12, 2011 6:40 pm
by JoKing
Yes, the upper forward mount on the right side is still at the paintshop... :roll:
The lower won`t be used.
I think i do not need it. But i am not sure. I will test it.
The ST3 engine offers no possibility to use it.
Posted: Wed Mar 16, 2011 5:04 pm
by JoKing
Today i flooded the frametubes where possible with fluid film, to prevent oxydation damage.
Posted: Sun Mar 20, 2011 10:25 am
by 907pasonut
JoKing wrote:
Motor into Frame:
looking at this picture you're about 3 to 4cm too high on the front sprocket, you may not be able to lower the engine,
but you could have a smaller sprocket setup to re-direct the chain away from swingarm,
I'm sure you could borrow a chain guide from some dirt bike...it should be doable :beer:
Posted: Sun Mar 20, 2011 8:26 pm
by JoKing
Sprocket& swingarm-axis are exactly on the same hight.
How does it look like in original?
Posted: Mon Mar 21, 2011 10:01 am
by Ducolaf
See a special tool, a green toothbrush. Recognizable, and also in my toolbox present. . . . :lol:
Posted: Mon Mar 21, 2011 4:07 pm
by JoKing
Ducolaf wrote:See a special tool, a green toothbrush. Recognizable, and also in my toolbox present. . . . :lol:
The MOST important tool. Next to my fingers...
Posted: Mon Mar 21, 2011 6:11 pm
by Finnpaso
JoKing, Looking that toothbrush: Too dirty teeths !!! Use more toothpast ! Do You have to kiss Your wife still ?
Posted: Mon Mar 21, 2011 6:14 pm
by JoKing
:lol:
Posted: Sun Mar 27, 2011 1:47 am
by Bock900r
JoKing wrote:Sprocket& swingarm-axis are exactly on the same hight.
Have a look
Posted: Sun Mar 27, 2011 10:35 am
by 907pasonut
after looking at both pics, the front sprocket looks to be in the same spot, (my apologies for barking up the wrong tree) it just didnt look right, I should of taken the cover off and had a proper look...then the swingarm chain damage was most likely caused by a loose chain, had a look at my swingarm and it also has a little chain groove, but very small, a chain guide or nylon pad might not be a bad idea to prevent this and check chain tension more often :beer:
Posted: Sun Mar 27, 2011 4:16 pm
by JoKing
How is the mileage of your bike?
Mine has altogether about 145.000km on the odo...
Posted: Mon Mar 28, 2011 3:13 am
by 907pasonut
not many, 17,623km
Posted: Mon Mar 28, 2011 4:04 am
by JoKing
I think you will have the same damage, when your bike reaches the 146tkm...
Posted: Mon Mar 28, 2011 5:20 am
by 907pasonut
you could be right...when I get some time I'll remove the sprocket cover and inspect if there is any damage near swingarm bearing, I still think this is not a design fault, but a maintenance issue :beer:
