Paso Dash
JoKing
Re: Paso Dash
Post by JoKing »
Sorry, i remembered it wrong. I paid 10,20€/piece :wacko: Half a year ago :-/
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
Re: Paso Dash
paso750 wrote: they usually come appart one day as the threaded part is only glued to the rubber block.
The foam rubber surround is there just to close the gap between instrument panel and fairing.
I glued mine again, after it went unglued
No problem since, by now...
pasoist
Re: Paso Dash
Post by pasoist »
Had a weird experience today.
I rode my Paso to work this morning (first time this year by the way). Suddenly I noticed that the clock on the dashboard was not a quarter till two, as it has been for the two years I´ve owned the bike.
OK, I thought. My brother went on a short ride on the bike yeasterday so maybe he´d turned the knob?
After a while I noticed that the clock was actually working, the pointers were in fact moving.
Now it seems to me that the clock only works while the engine is running, but I´ll have to check and make sure later.
Anyhow, pretty weird, huh?
Re: Paso Dash
Sounds like you need to take a pencil erased to the circuit board and give it a good clean.
pasoist
Re: Paso Dash
Post by pasoist »
Okay, after another day of riding my bike to work I´m now convinced that the clock on my dash has actually started working all of a sudden.
go figure?
Re: Paso Dash
no idea why it did but be happy.
On old Alfas like the one I had (´72) it was very common that the clocks stopped working. The parts were rare and as a consequence the prices were high. It seems one of the problems was dust or the grease gumming. I sprayed silicone grease in mine and it worked fine again until I sold it.
JoKing
Re: Paso Dash
Post by JoKing »
The one in the middle is the original dash- shock mount. The one in the righ is the one you get when you order @ ducati or stein-dinse with the correct part-#. It is the third part with wrong# from the catalogue now.
The one on the left another try to get the right one.
Anyone knows where to get some in germany?
/edith says: Ignore this post. I now saw G.`s post from march....
86` Ducati 750 Paso
plasmid
Re: Paso Dash
Post by plasmid »
JoKing wrote:The one in the middle is the original dash- shock mount. The one in the righ is the one you get when you order @ ducati or stein-dinse with the correct part-#. It is the third part with wrong# from the catalogue now.
ebay.de
seller: waschbe_puffer ( 178) 100.0%
Schwingungsdämpfer Gummipuffer Silentblock Ø10 x 10 M4 (260753133836)
