Paso Dash
plasmid
Paso Dash
Post by plasmid »
Greetings.
Does anyone have a schematic for how the dash/instrument pod is supposed to be mounted or secured?
Mine is kinda bouncing up and down. Initially I thought the foam is supposed to keep it in place
but maybe not.
Thanks.
JoKing
Re: Paso Dash
Post by JoKing »
It is mounted 3x with the shock mounts (#12).
Don`t think these are available anymore my dealer told me, I bought the last ones available....
But maybe that was only for Germany, or he lied...
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
Re: Paso Dash
JoKing, what did you pay ?
I got my last ones here: http://www.enduro-versand.com/shop/Gumm ... formteile/
I`m sure everywhere there`s a hardware store or a shop selling enduro/motocross parts that may have them.
plasmid check page 3 of the P750 FAQs.
Re: Paso Dash
Neoprene Vibration Damping Sandwich Mount Male/Male, M4 X 0.7, 1/2" Height, 3/8" Width
9225K61
(Same as 9376K201)
These are cheap and with a little shortening of the threads work just fine. Here in the states they are availible through McMaster Carr
JoKing
Re: Paso Dash
Post by JoKing »
Wow.... thats much less than I paid... (~5€/piece)
86` Ducati 750 Paso
Re: Paso Dash
it`s like the fork seals. They cost €33 at Ducati and 9,95 at a Polo/Hein Gericke etc. store
plasmid
Re: Paso Dash
Post by plasmid »
JoKing wrote:Image
Thanks.
Those mounts have rubber ends right?
So, the dash just lies on top of them and is kept from moving by the foam?
Re: Paso Dash
mounts are threaded on both ends with rubber in between. One end threads into the cluster( the end you need to shorten) the other is nutted in place on three brackets that are part of the fairing stay
Re: Paso Dash
they usually come appart one day as the threaded part is only glued to the rubber block.
The foam rubber surround is there just to close the gap between instrument panel and fairing.
Re: Paso Dash
$1.58 at McMaster-Carr
plasmid
Re: Paso Dash
Post by plasmid »
higgy wrote:mounts are threaded on both ends with rubber in between. One end threads into the cluster( the end you need to shorten) the other is nutted in place on three brackets that are part of the fairing stay
Ok, now I see the problem. Thanks
plasmid
Re: Paso Dash
Post by plasmid »
paso750 wrote:Image
Yep, that was the problem.
JoKing
Re: Paso Dash
Post by JoKing »
paso750 wrote:it`s like the fork seals. They cost €33 at Ducati and 9,95 at a Polo/Hein Gericke etc. store
I bought mine at a local standard-prts-dealer for ~2€/piece...
86` Ducati 750 Paso
Re: Paso Dash
One of the reasons why these silent blocks fail can be the speedometer cable. There are several cables that fit but if the one used is not long enough there can be tension on it which will transfer on the silent blocks. One of the signs the speedometer cable was replaced with one that`s too short is that the rubber retainer on the side of the fender is stretched when the wheels are on the ground or the front is lifted.
Re: Paso Dash
€2 for a fork seal is sensational ! Where is that ?
