New here
Derek
Re: New here
Post by Derek »
Tamburinifan wrote:Very clean bike, congrats!
Can you post a close up pic of the top case mount, near rear pegs?
Not sure which bit you mean Gert :?:
Do you mean the mounting for the top case frame?
Derek
Re: New here
Post by Derek »
davo wrote:Hi Derek, nice looking 907!
The standard pipes do look good!
How many km`s?
Is that a battery breather hose attached to the swing arm?
I eneded up buying a deka sealed battery to get rid of any battery acid problems.
26,500 miles, I think that's around 40,000 km.
The pipe is a for a Scott oiler. A type of automatic chain oiler popular in the UK, made in Scotland too :thumbup:
It has a new AGM sealed battery fitted.
Re: New here
Yep, the lower mount near pegs.
Re: New here
Nice bike, compliments :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
Gert, if you are interested, somewhere I have the same rack mount.
Asap, I will send you some pic.
Ciao :beer: :beer: :beer: :beer: :beer: :beer: :beer: :beer: :beer:
Derek
Re: New here
Post by Derek »
I can post a picture but it won't be until the weekend :(
Re: New here
Thx, Francie!
Derek, no hurry at all.
Just courious since I have similar top case frame.
Derek
Re: New here
Post by Derek »
Gert,
Here are some pictures of the top case frame mounts.
At the footrest hanger the lug on the top case mount is clamped between the hanger and the subframe at the rear bolt with a similar thickness spacer (washer) fitted at the front bolt.
At the back there is a bracket that clamps around the lower subframe tube.
JoKing
Re: New here
Post by JoKing »
Wooooo..... he as an original tool kit!
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
Derek
Re: New here
Post by Derek »
JoKing wrote:Wooooo..... he as an original tool kit!
Yes. Original tool kit, Owners Handbook, 906 Paso Workshop Manual with 907ie supplement all came with the bike as well as an assortment of shims. :)
Re: New here
that looks like a GIVI luggage carrier, but if it is it seems it`s not mounted correctly (at the footpegs).
http://www.box.com/shared/4go2jdg17i
Derek
Re: New here
Post by Derek »
paso750 wrote:that looks like a GIVI luggage carrier, but if it is it seems it`s not mounted correctly (at the footpegs).
I've only just aquired the bike so I'm pleading not guilty. From the diagram it looks like the footpeg mount should be on the outside of the hanger but to be honest the way it is mounted looks a lot tidier to me.
Jaffa
Re: New here
Post by Jaffa »
Mine was mounted exactly the same...but removed now as I think the bike looks far better without them.
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
Re: New here
If it`s mounted like that I`d at least put a washer with the same thickness under the other footpeg bracket bolt as otherwise you`ll have stress on the material and the two bolts.
Re: New here
