Turn signal Lens for front?
du907
Re: Turn signal Lens for front?
Post by du907 »
Firehawk75:
better check to see if it is indeed available. At a lot of places with web sites you can order on the web all day long but then you may get an e-mail stating that the item is not available or on back order and then they will "let you know" when it comes in. I contacted Omaha a couple of weeks ago and they told me the the lens was not available.
du907
just as a general sidenote
when having a dealer or shop check availability for parts as old it`s always better to look up the parts catalogue and write down all part numbers before. I may be wrong but I think the Supersport is the earliest model in Ducatis electronic parts program, all others are only on microfiche. So some may reply they don`t have anything just because they`re too lazy to dig up the old microfiche reader or simply because they don`t have one. They don`t have any problem checking availability of part numbers. Getting the part numbers is a shop`s problem.
paso750 wrote:I may be wrong but I think the Supersport is the earliest model in Ducatis electronic parts program, all others are only on microfiche.
The 907 is in the electronic parts program, the 906 and 750 does'nt.
I don't know about the availability of the lenses in Italy.
I bought many ones some time ago and don't need them.
If someone is interested, I could ask to a local dealer.
Derek
Post by Derek »
I ordered a pair from the eBay seller and received them last week. The bike looks so much better with them fitted :)
Tondonic
Post by Tondonic »
I have a new set of lenses that I'm putting on ebay tomorrow.
