Re: Bleeding/replacing clutch
Posted: Fri Feb 08, 2013 8:28 am
what bike did that clutch slave exactly come from (model and year) ?
I`m not sure I understood the rest.
Now there is an expression I've never heard before, can I use it with your kind pemissionMc tool wrote:I think the correct term is " penis fingers " .... fucks everything he touches![]()
He's gotta be taking the piss...surely907ie wrote:What do you mean mix the epoxy? I thought the white part was the glue. The other part smelled like chocolate but it tasted bad.
paso750 wrote:you don`t know how many bolts I snapped when I was younger
no shitbut I did it on the kickstand, and it was higher than normal when I put it back on.
It`s nice to be one of the youngsters at 43Younger![]()
paso750 wrote:It`s nice to be one of the youngsters at 43Younger![]()
in reverse we should open a new topic to figure out why most Paso owners are old farts of 60+
That or younger is what I would have guessedDang I thought I was starting to get old, almost 22.![]()
The best would be you have the bike standing on its wheels and someone to hold it upright while you fill up the oil. Of course while you drain the oil on a warm engine you check the oil level when it`s cold!I mean I put the bike on the center stand not kickstand when I added the oil, I used the wrong word. I was supposed to do it there and not a normal position like riding?
Looks fine. It`s also good the last owner added a case saver. A chain with a riveted lock would be better though than one with a clip lock.Clutch Slave Cylinder
.The oil was changed about 900 miles ago, with a new fuel filter. What fuel filter should I use to change it? The auto place close by is Autozone, and I can order anything from their website there and go pick it up
sure or is it center stand not kickstand ?!Oil level on kickstand (not center stand)
That the engine just burns the excessive oil isn`t good and it`s still over max.Oil level in riding position
It seems like it is where it should be, but a few days ago it was higher than this, after I had it turned on for about 5-10 minutes, now it is here, and the smoke is less than before.
Think ! When the engine is running the oil is circulating hence there`s less in the oil sump.Oil level in riding position, turned on
Is it supposed to be lower when it is turned on? You can barely see the oil position at the very bottom.
Too much oil. As you say the bike is smoking less it`s unlikely it`s coolant mixing with the oil which would be really bad.After turned off, in riding position
This is where it looks bad... frothy more yellowish color... After I run it for about 1-2 minutes then turned it off, then it has these little bubbles and yellowish color.
The header cross is hollow so the oil that ran down the engine probably collected in there. Clean it out.This is where the smoke is coming from, whitish/grayish color
This is right at the bottom of the oil case, right above the base of the exhaust area. The smoke is much less than before, and I do have some brake fluid spilled.
I hope for you it is.I was worried about a sound as well... I can't remember, it has been a while since I rode this, but there appears to be slightly more rattling sound coming from the engine, but that could be my imagination.
Oil filter.Fuel filter
This looks like it would be hard to take off with my hands, I just need one of those tools to take it off right?
no. I wish at least once you`d take a look at the service manual or parts catalogue.Is this where you drain the oil?
What is the screw at the bottom for?
Also does anyone have any idea what size this is? I have a 24 which is too big, and I think the next size bigger socket I have is 18 or 19 which is too small.
According to the rules of gravity the oil drain screw would be at or near the lowest point of the engine ...What is this? It is on the bottom of oil tank, but over to the left, looks like a large hex can fit inside
This comment disappoints us all. After you changed the clutch slave cylinder and bled the clutch you should be able to change the oil which is one of the most simple things to do but then ...If I was to go change the oil, would it be ok to drive the bike to the Autozone and change there, or should I walk there and bring the parts back. (1.2 miles away, about 3-4 minutes driving with all the lights.)
get someone to hold the bike uprightWhen I change the oil, should it be in riding position (just held up in the same position as if I was riding) or center stand?
Right, fill it up to the middle of the two lines when the lower line says MAXWhen I add more oil, I put it to the middle of the two lines, and then how long should I keep it on before adding more to see if it goes down at all?
if you have your pics on Photobucket just click on one picture, then put the mouse on it and you`ll see a drop down menu including "rotate"p.s. Some of the pictures are sideways, the one where I think you drain oil with the screw also is completely upside down...
