new Paso owner
Re: new Paso owner
All my vehicles have NGK plugs but for no particular reason other than the local supercheap autos sells NGK and Bosch plugs and the bosch are dearer
Re: new Paso owner
High End Bike ? Which would that be
Re: new Paso owner
Thanks for the input guys, I can't wait to get this thing on the road
- ducatidaddy
Re: new Paso owner
Welcome to the forum birdduck, I have an 88 750 Paso (light blue) and she has been pretty consistent with the Champions. Like you I was a bit skeptical as being a kid who grew up around performance bikes in the US, Champions werent ever the choice of my tuners, but as the 750 had them on it to start, I stuck with it and havent had any problems. I'm out in KS now where it is a little more dry but still running like a top.
All in all have fun and ride safe!
Troy
Troy
2003 Ducati 999 # 808,1998 900CR,1990 906 Paso #257,1988 750 Paso
1983 Honda CB900F,1985 VF1000R,1986 VF1000R (Euro),1989 Hurricane 600,1992 CBR600F3
1988 Kawasaki Ninja ZX250R,2000 ZX9R (Race)
1981 Suzuki GS850G,1986 GSXR 750,1987 GSXR 750,1990 GSXR 750
Re: new Paso owner
I guess high end for it's timehiggy wrote:High End Bike ? Which would that be![]()
- randtcastell
Re: new Paso owner
fugging nice color scheme with the paint and seat cover. Not seen a yeller '87 before.
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
1973 Honda CB450
2022 KTM RC390
- Skins
Re: new Paso owner
Very, very nice! Well done, sir!
Re: new Paso owner
Just waiting on some belts to be ordered, then I can start on getting some tires.. then it's on the road.
- Skins
Re: new Paso owner
Do you have a manual? Keep the chain adjusted slightly on the loose side for best gear changes and smoothest running.
Re: new Paso owner
No manual, but I have found everything I have needed for info online.. what is considered loose?
- Skins
Re: new Paso owner
The owners manual says the chain should be adjusted to 15-20mm play with the rear suspension compressed halfway. So 20mm would be loose.
It's easy to compress the rear suspension with the bike on the centre stand and a few turns of rope over the saddle, with some padding to protect the saddle and plastic, and under the top of the the rear wheel.
- ducinthebay
Re: new Paso owner
I too have switched to the Champion plugs. I tried a range of plugs, and my 1990 Sport ran best on them. I too was surprised, as I had a generally low opinion of them, but then again, every company makes a budget product that gives them a bad rap I guess. Best part is that they are only a few dollars at my local auto parts store. Cheap and good, no reason not to change them every spring.
Re: new Paso owner
Can one of you guys post a pic of the shinko tire mounted on the bike? Or other options mounted?
Re: new Paso owner
Yeah they do look good yellow , mind you neither of us look this good now ( post crash ) , just havin a wee pipe before the lunacy
