Page 4 of 4
Re: 750 Paso front brake adapters to swap 320 rotors to M1R
Posted: Mon Feb 04, 2008 1:02 pm
by Finnpaso
Those adpters look very similar, as i use now with just same calipers, BUT to 280mm rotors. I want calipers to 320mm rotors wit same black brembos... :thumbup:
Posted: Mon Feb 04, 2008 1:08 pm
by paso750
and that is what they are also offering, They have different size adapters as it says: 280 to 280, from 280 to 300, from 300 to 320
You can contact them at: ducati-dortmund@online.de
As it seems the parts on ebay are original MQ, these seem self machined.
(send CC to ducati-dortmund@t-online.de as I think the email adress above, which comes from their site, is incorrect)
Posted: Mon Feb 04, 2008 5:19 pm
by persempre907
paso750 wrote:Antti,
either get the parts I showed you on ebay or go here:
http://www.ducati-development-dortmund. ... pantah.htm
(or get a Paioli fork and you don`t need an adapter :mrgreen: )
Very interesting source, and also the prices are quite fair :thumbup: :thumbup: :thumbup: .
Antti,
I guess they could make the adapters from 280 to 320.
So, only €. 65 to have both those adapters just done.
Posted: Tue Feb 05, 2008 6:39 am
by Finnpaso
intresting.... But is that 65€ for pair, or one ??? Gerhard! If pair, then i contact to them... :thumbup:
Posted: Tue Feb 05, 2008 5:04 pm
by paso750
:mrgreen: I guess a 300 to 320 adapter would be fine also.
regarding the price it`s per piece. As you can see on the site they offer also adapter for the 08 Brembo calipers and different size discs and these cost € 170/pair.
Posted: Wed Feb 06, 2008 6:48 am
by Finnpaso
Yes! Was that 08, that black original 750/906 caliper? After i have used those 4 pistons(from 907IE)in my 750 Paso, i never go back to those original ones.... NEVER! :thumbup:
Posted: Fri Mar 21, 2008 4:44 pm
by paso750
Hey Antti,
before you left on vacation I had pointed you to some MotoQuality adapters on ebay.
As you weren`t interested (although they were exactly what you were looking for) and they may come handy for me (Marvic rims with bigger brake discs) I bought them.
Here`s the drawing. It cost me todays rainy afternoon and as I have a bad headache now I didn`t doublecheck everything but I think it should be ok. (the .ppt file is better printable)
http://www.box.net/shared/tnyfou50ck
PS: the picture above shows the adapters mounted incorrectly btw. What the adapters mainly do is shifting the caliper backwards to make it fit on discs with a bigger radius.
Posted: Fri Mar 21, 2008 4:59 pm
by paso750
the adapters fit with both 300 and 320mm discs. It just depends which way round you mount them.
Here a pic of my 280mm adapter (left) and the 300/320mm adapters.
As the mounting holes for the caliper are not centered, the caliper will be in a different position depending on if you put the adapter on the left or right side of the fork.
Posted: Fri Mar 21, 2008 7:47 pm
by Finnpaso
Hi !
Currently i have just same adopters, as You(those in left). I use them with normal 750 Paso M1R fork with 907IE black calipers and normal 750 Paso rotors.
Seems, that now i have found, what i was looking for..... :thumbup: :thumbup: :thumbup: :thumbup:
I REALLY apperiate You, Gerhard, how much You have time to do all that work with computer :thumbup: :thumbup: :thumbup: I downloaded already measurements to laptop, so seems, that i give them close times to my friend, "lathe man"... VERY good drawings, so very many thanks to you, Gerhard.... :thumbup: Hopefully we meet one day and then i buy dinner to you.... :thumbup:
Btw, i noticed from You last foto, that there is stamped both 300 and 320 !!!!
Posted: Fri Mar 21, 2008 7:56 pm
by persempre907
Finnpaso wrote:Btw, i noticed from You last foto, that there is stamped both 300 and 320 !!!!
Very interesting,
So you can put without problems the 300 and 320 rotors only turning the adapters :shock: :shock: :shock: :shock: :shock: :shock: .
Ciao :beer:
Posted: Fri Mar 21, 2008 10:27 pm
by Finnpaso
Yes, Frankie! :mrgreen:
Posted: Sat Mar 22, 2008 2:08 pm
by paso750
Antti, there`s not much else to do on a rainy, cold afternoon on a holiday! :truck:
If you get .eps or .dwg drawings let me know. I`ll upload them here.
If I missed some measurement let me know also and I will check. I used the file that Roy made for me for the old adapters and just modified it a bit.
Posted: Sat Mar 22, 2008 10:03 pm
by persempre907
Another good idea would be drawing the Motorquality right ones, that are very clever.
Replacing the stock rotors with the 320 ones would get an huge braking improvement.
Ciao :beer: :beer: :beer:
Posted: Sun Mar 23, 2008 9:41 am
by paso750
:huh: ?! Those are in the last drawing.
