Now i have normal cast iron original 280mm rotors with adapters to 4 piston black Brembos, but planning in future 17" conversion with same calipers to original M1R fork, but with 17" wheel and 320mm rotors.
All info will be welcome
Here there is the conversion to 320 mm. rotors, 40 mm. calipers (Brembos black or earlier goldline) keeping the 16" wheels.Finnpaso wrote:Yes, i meant adopters between 320mm normal Ducati rotors / 4 piston Black Brembos(or early "golden line" Brembos) / original 750 M21R fork.
Yes, it's right, I was mistaking.ansim wrote:Nope, it's still the 280mm rotors and 16" wheel.
Check these pictures, http://www.geocities.com/750paso/paso/4 ... sult12.htm
But it is not so tight with 40mm spacing calipers.
