Page 4 of 42
Re: Oil leaks 89 900 ss
Posted: Sat Jul 01, 2017 9:44 am
by paso750
maybe take it to a shop. They may have a bigger compressor. (Someone will have to hold an open C clamp over the piston to prevent it from shooting out.)
Posted: Sat Jul 01, 2017 12:22 pm
by HIGHWAY89
Maybe I can try a bigger compressor I have 14cfm but already using 8cfm so that sort of buggers that idea , thanks anyway I'll get it eventually
Posted: Sat Jul 01, 2017 12:35 pm
by HIGHWAY89
It may work if I can hook compressor to clutch cover directly and a Big c clamp
Posted: Sat Jul 01, 2017 1:00 pm
by paso750
careful tho. I've heard of one guy who shot the piston in his face. (that wasn't me)
Posted: Sat Jul 01, 2017 1:10 pm
by HIGHWAY89
Yeah never tried anything like that , if I can make the connection work I have a lever so I should be able to give it little bursts and I can probs just lay it on a piece of wood on ground
Posted: Sat Jul 01, 2017 2:37 pm
by HIGHWAY89
I used rapidfix to join a safety nozzle from basic airtool kit and a male nitto fitting , I'll try it tomorrow in line with glue guidelines and take safety precautions,Good test of the rapidfix which I have heard rave reviews
Posted: Sat Jul 01, 2017 2:39 pm
by HIGHWAY89
The safety nozzle is a reasonable fit to the thread in the case for bleed nipple
Posted: Sat Jul 01, 2017 4:54 pm
by HIGHWAY89
Rapidfix has the thumbs down at this stage, i ended up with a bronzed finish nitto female to the banjo with the hole drilled through and the nipple where it should be, looking forward to test it out tomoz, cheers
Posted: Sat Jul 01, 2017 4:57 pm
by paso750
fingers crossed
Posted: Sun Jul 02, 2017 3:02 am
by HIGHWAY89
So much for that , everything held together even the damn cover and slave unit, I guess I gave it about 120 psi for five minutes , may have to try the plan b and try pull it out
Posted: Sun Jul 02, 2017 3:18 am
by HIGHWAY89
Just thought , maybe a little gentle heat to the boss on the inside of the cover and try to tap the whole thing out?starting to annoy me but still don't want to use force and damage stuff (Sorry if annoying you guys as well but this little thing is getting ridiculous)
Posted: Sun Jul 02, 2017 3:24 am
by HIGHWAY89
Is that a bad idea as I don't want to distort cover, any ideas there, thanks
Posted: Sun Jul 02, 2017 3:58 am
by HIGHWAY89
She's starting to move now out about 5mm mix of big vice, air connected, gentle heat and a rubber hitter from outside cover, gunna let it cool hit it with penetrate then try it all again , happy days
Posted: Sun Jul 02, 2017 4:27 am
by HIGHWAY89
She's out and I wish I could say that didn't take long, persistence paid , your post about bigger compressor is what really helped , now to see what I can save and what parts are needed, then I can get back to the start of this whole gaskets and seals thing, cheers again
Posted: Sun Jul 02, 2017 6:43 pm
by paso750
success finally. I probably wouldn't have used heat for the sake of the O-ring but as you'll replace that anyway...
Can you see why the piston was stuck so badly? What`s the condition of the piston and cylinder?
Pictures are always welcome
