Page 6 of 42
Re: Oil leaks 89 900 ss
Posted: Tue Jul 04, 2017 12:37 pm
you have a pm
Posted: Tue Jul 04, 2017 1:10 pm
by HIGHWAY89
One of those dumb questions , what's that
Posted: Tue Jul 04, 2017 1:31 pm
that's a private message. When you're logged-in you`ll find the link on top where it says "1 new message"
Posted: Wed Jul 05, 2017 8:40 am
by HIGHWAY89
So glad I stripped those cases off , the wires coming off the stator are absolute s toast, original, really knackered cracked,split and couple areas 4mm long sections of bare wire once it was exposed
Posted: Fri Jul 14, 2017 6:14 am
by HIGHWAY89
Just cleaning cases and clutch parts now as money is real tight hope to get some parts in a couple of months and start getting the engine all buttoned up again thanks for all your input and suggestions so far
Posted: Fri Jul 14, 2017 10:06 pm
by Mc tool
I recently ( year ago ) re-did all the alt winding tails / connections on my quad as it had the same crispy insulation and I just resleeved the exposed wires with heat shrink tubing. I had to unsolder the wiring harness from the winding tails and slip the tubing over the wire and re solder the join. I used several 1-2 inch lengths of heat shrink rather than one long piece , then laid all the wires where they would normally rest , arranged the heat shrink so as to cover all exposed wires ( everything inside the motor) and then applied the heat so the tubing shrunk into the correct shape ( instead of shrinking it and then trying to get it to sit right after ). I was a bit dubious about using heat shrink but after the 3rd auto sparkie told me that's all they use I gave it a go , and its been a year and that quad engine gets fanarklin hot ( old air cooled Suzuki........ they are known for being hot runners ) and its still working fine
Posted: Sat Jul 15, 2017 9:40 am
by Derek
I had to replace the cable to the pick ups for my Pantah entirely. The insulation was so brittle it just fell of as soon as I touched. I soldered new wires direct to the back of the pick ups and used heat shrink to hold them all in place.
Posted: Sat Jul 15, 2017 11:52 am
by HIGHWAY89
Yeah thanks for the advice and pics guys,the wire is in pretty bad shape so I guess I need to undo the solder joins on stator and match the cable, omitting the 3rd wire and give it all a good heatshrink, orig wire look like aluminum?
Posted: Sun Jul 16, 2017 9:25 am
by Derek
HIGHWAY89 wrote:Yeah thanks for the advice and pics guys,the wire is in pretty bad shape so I guess I need to undo the solder joins on stator and match the cable, omitting the 3rd wire and give it all a good heatshrink, orig wire look like aluminum?
Your original wire is unlikely to be aluminium, you can't solder to it, at least not easily. It is more likely to be tinned copper.
Posted: Sun Jul 16, 2017 6:44 pm
by Mc tool
Posted: Mon Jul 17, 2017 1:08 am
by HIGHWAY89
I might just drop in at the autospark local who did gave me some good help with cable and connectors to wiring harness, he may shed some light there, I guess there's a good reason why it's not copper wire
Posted: Mon Jul 17, 2017 2:48 am
by Mc tool
are you sure its not copper , tinned as G sez .
the reason for aluminium windings is cost driven but I don't recall ever seeing them on something as small gauge as a alt winding
Posted: Mon Jul 17, 2017 12:38 pm
by Derek
The windings are normally wound from enameled copper where the enamel (varnish) provides the insulation. The wires from the stator are usually from pvc covered copper (tinned or otherwise) and soldered (or crimped) to the stator terminals.
Posted: Tue Jul 18, 2017 4:25 am
by HIGHWAY89
Yeah you're right the windings are copper it's only the wire coming out of the stator that are silver in color
Posted: Tue Jul 18, 2017 4:29 am
by HIGHWAY89
Not sure as to why I have 2 yellow wires , 1 connected to each of the 2 terminals, the red 3rd wire looks as though it's never been connected?
