Page 7 of 8
Re: 907 EPROM
Posted: Thu Jan 13, 2011 10:23 am
by paso750
There exist special pliers to remove chips but one can do it also without. If it sits on a socket (and is not soldered on the board) pull it off gently. Sometimes you`ll have to start on one side and then lift on the other. Careful though as you don`t want to bend any pins.
Usually chips/ICs have a round mark on one side on the top so you know which way round is the correct position.
When inserting the new one look close that all pins are in the socket holes before slowly pressing it down. On new chips the pins are sometimes bent slighly more out or inwards.
I never did this on a 907ie but I guess it`s the same as on any other electronic device.
As many chips don`t like electrostatic charging you should earth yourself before touching the chip.
Re: 907 EPROM
Posted: Thu Jan 13, 2011 10:57 am
by Jaffa
Well guys, thanks for the advice,
Had the same problem as Claude though,
all plugs in, reinstalled the box, reconnected the battery,
ignition key on....dash lights up....gooooood,
but...no fuel pump...not so good.
Starter motor turns over the engine, but no starting.
Pulled the FBF reinsterted the old chip and all good.
Ahhh well, FBF another fail. Email on the way.
:phone: :phone: :phone:
Re: 907 EPROM
Posted: Thu Jan 13, 2011 2:22 pm
by Tamburinifan
& u r sure it isn`t mounted the wrong way?
50% chance.....
Re: 907 EPROM
Posted: Fri Jan 14, 2011 1:08 am
by Jaffa
Tamburinifan wrote:& u r sure it isn`t mounted the wrong way?
50% chance.....
Good point, I did mount it what I thought was the same as the chip that was in there, but will have another go after work....see if that produces anything. :wacko: :wacko:
Re: 907 EPROM
Posted: Fri Jan 14, 2011 8:57 am
by 907pasonut
I did email FBF and received a brief reply on 2/Jan...working with Mr Ferracci for a resolution...and that was it :huh:
so Im still not sure whats going to happen, but they must have a bad batch...I hope it doesnt take too long for a resolution :zip:
Re: 907 EPROM
Posted: Fri Jan 14, 2011 9:18 am
by 900streetfighter
If you put a chip in the wrong way round it kills them. Guess how I know.
Re: 907 EPROM
Posted: Fri Jan 14, 2011 11:44 am
by higgy
You had a friend who knew a guy whose mother had a son that once put a chip in backwards :?: :beer: :beer:
Re: 907 EPROM
Posted: Fri Jan 14, 2011 8:34 pm
by Mc tool
higgy wrote:You had a friend who knew a guy whose mother had a son that once put a chip in backwards :?: :beer: :beer:
I think that you have had a chip put in backwards :lol: :lol:
Re: 907 EPROM
Posted: Fri Jan 14, 2011 9:12 pm
by Jaffa
Well gents, I must say Ferracci have been very helpful with my problem...and it does appear as though it was MY problem :oops: :oops: :roll: :roll:, ordered the wrong chip....embarrassment.
Well, they are sending me the correct chip and everything should be peachie.
Once again, not the fault of Ferracci, mine.
:banghead: :banghead: :banghead:
Re: 907 EPROM
Posted: Fri Jan 14, 2011 9:43 pm
by 907pasonut
900streetfighter wrote:If you put a chip in the wrong way round it kills them. Guess how I know.
just received another email from FBF...we are sending another chip with instuction sheet...
I think this will come with the heading...eprom installation for dummies :lol: :lol: :lol:
I do admit as I didnt see the notch on the side of the chip...I went by the writing on the chip and kept that the same way around, but of course the notch is on the wrong side :banghead:
and if Mr Ferracci is monitoring this site...thank you very much for a replacement :beer: :thumbup:
Re: 907 EPROM
Posted: Fri Jan 14, 2011 10:01 pm
by higgy
No chip,down to my very last brain cell :fart:
Re: 907 EPROM
Posted: Sat Jan 15, 2011 11:40 am
by Tamburinifan
hi all...I finally replaced the chip, a ferracci stage one (exhaust only chip), re-assembled everything put my helmet and gloves on turn the key...no FI pump...starter motor ok
...then I thaught the chip must be the wrong way around, turn chip around, tried again...still no go
...fit old chip back on, no problem, fired up straight away
obviously the chip has some sort of brain damage...after all this time I was looking forward to try it out
So what the problem w the first chip?
It was malfunctioning fr FbF or did you ruin it when installing 2 different ways?
Re: 907 EPROM
Posted: Sat Jan 15, 2011 12:19 pm
by 907pasonut
I just realized that my 'fuel injected motorcycle' chip is actually a FIM chip :mrgreen:
the FIM chip is still good...but Im sure I put the FBF chip the wrong way around the first time, and according to 900streetfighter that frys the crap out of them...WTF...I kept the writing on the chip the right way around, same as the FIM chip but the notch is on the opposite side :dunno:
so the chip mulfunction was most likely caused by the nut that put it in, mind you...in my defence, the chip didnt come with any instructions :wacko:
Re: 907 EPROM
Posted: Wed Jan 26, 2011 3:45 am
by 907pasonut
...FBF chip installation, take 2...
I received the second chip (thanks Mr Ferracci :thumbup: ) installed it this morning, not before putting rubber gloves on and making sure it was the right way around,
turned the key on, this time it fired up, but needed more accellerator advance (choke?) and if you removed the choke before the motor warmed up it would stall, so it took about 10min for the motor to idle without any accellerator...the previous FIM chip was on the bike since 92 and this would start the motor very quickly and needed a lot less choke :huh:
once the motor warmed up I took the bike for a spin, and I was impressed, the torque curve is much smoother and I think the motor is running a fair bit leaner (but I'm only guessing) the motor is much happier and responsive from 2000rpm...finnpaso, under low accelleration with no engine stress :thumbup:
I only went for a short ride, but it appears that this FBF chip is a very good product and agree with Nigel (blazing928) and would say if you have any issues with your FI system dont hesitate to get one...for $150 you cant go wrong :beer:
I will now get one for the 851 as well :thumbup:
The P7 FI system may not be the ultimate in FI technology...but its still good :mrgreen:
Re: 907 EPROM
Posted: Wed Jan 26, 2011 12:14 pm
by Tamburinifan
Good to hear, claude!
Did you return the chip, was it faulty?
About mounting chips,
got my info that fitting them wrong way doesn´t hurt fr another Forum.
PM`d the guy who dunnit, answer:
No I did not ruin the chip at all. Flipped the chip around and the bike started right up. The bike now has 2000mi on it and ready for a going over.
