new Paso owner
Re: new Paso owner
So, BirdDuck, where exactly in the grand ol USA do you live that you can't find Ducati parts?
After e-bay and Craigslist, there's ducati breakers like Nick Anglada https://www.facebook.com/UsedDucatiParts and GuzziTech.
Everything is possible to find on the internet, of course patience is required, and a paypal account. Some parts have taken me several years to find, like my 300mm cast iron full floating Brembo rotors, new in a box.
But if you are interested in a set of stock Mikunis and a stage 1 kit, drop me a line. they are in the garage some where, and I'm on the Dellorto wagon, so I won't be using them.
birdduck
Re: new Paso owner
Post by birdduck »
its mostly keeping cost down, didn't intend on running into issues of ham handed previous owner :(i am in Utah. how much are you thinking? and would i need manifolds as well?
Re: new Paso owner
inlet manifolds + rubber boots + 2 throttle cables & accelerator throttle + SS choke cable + air filters + the usual small bits
birdduck
Re: new Paso owner
Post by birdduck »
has anyone used the round slide mikuni carbs? there is tones of those around for cheap. i believe they are mostly off two stroke applications, i thought i have seen them on some other models of ducs maybe the bevel engines?
Skins
Re: new Paso owner
Post by Skins »
:cool:
Phil has made you a good offer. Why don't you do as he suggested, and drop him a line?
birdduck
Re: new Paso owner
Post by birdduck »
i did.. :)
Re: new Paso owner
He will be getting the boots, manifolds, stock carbs, Stage 1 Dynojet kit, and a throttle if I can find it. After owning it for 5 years, and taking up shelf space, I'm glad to make some room
I'll be making some more room in the coming weeks as I might be moving shortly, and need to start cleaning up.
Skins
Re: new Paso owner
Post by Skins »
:cool:
Well done, Phil!
birdduck
Re: new Paso owner
Post by birdduck »
Found the problem.. 7v to the coils.... Fixed.. 11.7v now :) thanks for the nudge on checking the coils.. still want carburetors though :D
birdduck
Re: new Paso owner
Post by birdduck »
WOW talk about a different machine now 0_o!
Re: new Paso owner
Even better with some Dyna Coils and a relay inline.
birdduck
Re: new Paso owner
Post by birdduck »
wired it up last night. direct power from the batt to a relay with on with key on. every connection is soldered and shrink wrapped, 8ga wire feeding the coils juice :D.. the electric engineer for ducati must have been on acid or something with how all the systems are run :S
Re: new Paso owner
8ga is just a bit over the top :mrgreen:
Re: new Paso owner
Its not done till its overdone.
Jeffreyt
Re: new Paso owner
Post by Jeffreyt »
If you're thinking Mikuni carbs, here is what mine look like:
IMG_0752 - CopyB.jpg (315.75 KiB) Viewed 12652 times
