Hi everybody!!! Just got back from purchasing my red 92 907ie. It is beautiful and in very good shape since it was owned by an AirForce person for 10yrs. My question is: What would be the biggest (wide) tire that I can install on my 907 rear? And based on experience I would purchase Metzeler but I'm open for suggestions. Thanks to all of you who reply to this message. I still have my 750 red Paso, don't know if I should sell it and concentrate just on the 907.
Oh! another thing! Why is it that I felt my 750 Paso a lot heavier than my 907 when moving it around in the garage? Isn't supposed the 907 to be heavier? Thanks again!
For tires I run the Dunlop Sportmax D208 and have been pretty happy with them. I would stick to the 170 rears...the bike was designed for them and from what I've read, going wider won't help your handling.
Thanks pencilbeam for your response! Just wanted to know if a wider tire would work better and look better at the same time! My regards and thanks again!
907ie has bigger engine (heavier), which is also water cooled, so waterpump, radiator, expansion tank add to weight, just as the extra weight of the efi system.
Also bigger wheels, which means the centre of gravity is higher, what probably makes the bike feel heavier than its actual weight difference.
Hi Michiel, I understand about the water pump,fluids,bigger wheels, radiator, bigger engine... I believe you didn't understand my question or got confused! According to logics the 907 should be heavier but what I stated on my message was that why does the 750 feels heavier than the 907? instead of the other way around which is what logics make you believe...
Hm, I must be getting Alzheimer, hehehehe. I'll just blame the tropical temperatures over here, and my busy schedule (no point admitting I was not reading carefully ).....
You are completely right.
Strainge however, I owned a 750 (way back in '92) and had the privilege to ride 907's several times (I was working for a big bike shop in Holland that also had the Ducat / Cagiva importer under its wings..), and cannot remember any such feeling. I always felt the 750 as a lighter bike, also in handling while moving it about. Mind you, this is already a long time ago and memory does tend to remember only the positive things
Hi Michiel, not to worry! That happens to everybody! The only logical reason that I can think of is that the 750 being lower due to the 16" rims the center of gravity and weight distribution is closer to the ground therefore making it feel heavier to move around at the garage. :ugh: Anyway, thanks for your response and good faith.
To my knowledge, a lower cg would make the bike feel lighter and easier to move around. So there must be another explanation for this .
Interesting to try to find out I think. One thing that comes to mind is the tires. I can imagine the 750 with its 130/60/16 front and 160/60/16 rear (original tire sizes) has a slightly flatter cross-section, taking a bit more force to rotate sideways etc.
All this talk about Paso's sure does me want to have one again, hehehe.
My experience is that the 180/55 rear will work fine on the 907. It looks cooler but may not actually make the bike handle any better. It could increase ground clearance a little, however you can change ride height a little with aftermarket suspension like Penske. The 190 is too wide and will most likely touch the swingarm or something.
dp
