rebuilding my clutch pack, and i think everything is not lined up properly.
pressure plate has 2 marks on it (1 and 2) - what does this line up with?
clutch hub has a dot on one spline, what does this line up with?
also, my clutch piston bearing seems to be worn, any idea on replacement parts info?
thanks!
all help is appreciated..
clutch rebuild info
Re: clutch rebuild info
......Hi pikey what clutchpack did you get? was it different steel plates Im guessing 22A hasnt difference ive been off my bike A year amid total confusion here in u.k. cant answer your Questions they are the same id like to know? but obviously when you pull all the plates toward you and plate with 1&2 on it evenly tighten the bolts so as not to strip your threads maybe the numbers are for this who knows? maybe gerhard hes the master for me like the yoda in star wars (knowldgable not ugly!) give him a post......desmodave u.k. god bless america.pikey wrote:rebuilding my clutch pack, and i think everything is not lined up properly.
thanks!
