Hello,
i will mount Dellortos on my 906. My question, is it nessecary to use the original fuel pump? Can i use a Mikuni vacuum pump from a monster?
Greetings from Germany
Timmy
fuel pump Dellortos
- Finnpaso
Very simple question! Dellortos really DONT need ANY fuel pump! Those are designed to function WITHOUT any pump.... But somekind fuel valve in output of tank can be good. I add to my 750(with 40mm Dellortos) vacuum fuel valve. It takes vacuum from inlets and function quite well.....
- Finnpaso
Jomo, seems, that U really have some other problems also, cause Dellortos DONT need any fuel pump, no matter, how much fuel in tank... I know many guys, who have changed Deoortos after Weber, but NOWBODY use fuel pump with Dellortos. Surely that can be used, but them MUST make return fuel lines with (needle)valves to tank.
- Finnpaso
If U have fuel pump with Dellortos, then U need those return lines, but if U use only gravity feed, then those return lines are useless.... then Dellortos take just that amount of fuel from tank, what they need. SIMPLE!
