LED Bulbs
Posted: Thu Dec 21, 2006 3:07 am
by Wanderer
HI all. Since electrics are such a challenge for us, would the use of LED bulbs in the signals and tail help out the power consumption? Does anyone have the expertise to answer if this is a useful consideration or not?
Posted: Thu Dec 21, 2006 9:46 am
by persempre907
I think the current saving will not to be too much, since you could replace only the parking, the stop and the indicator lights, that are not always working and no matter there would drain very little current.
But, about this matter Antti could say the decisive word
Posted: Thu Dec 21, 2006 1:48 pm
by jcslocum
I don't think so. The draw from these items isn't the root cause or even a contributing cause to the electric issues of the Paso.
A more useful task would be to clean all of your connections and grounds.
Posted: Thu Dec 21, 2006 8:37 pm
by Finnpaso
Guys are right! That dont save so much current, so only good things are, that LED blinkers least much longer and they are fast, BUT at leat here those LED bulbs are illegal(i have 2 in both Pasos backlights and one pair in ST4S rear blinkers, but they are "nothing so special" stuff). I use such in Paso backlight, cause its bolted so heavily to frame and normal bulbs are very often broken, caused by vibration of Ducati engine. That is ONLY reason for using them... Anyway, polices have here more important things, than check mc bulbs.... :laugh: :laugh: :laugh:
Posted: Thu Dec 21, 2006 9:45 pm
by zap
hi
i also use led bulbs for the back/stoplight and blinkers and i've exchanged all the dashboardlights for leds.
to do this alltogether, i could easily install a more powerfull headlight.
works great for me!
Posted: Fri Dec 22, 2006 3:36 pm
by Finnpaso
Posted: Sat Dec 23, 2006 8:08 pm
by macchiman
For the same reason of reliability and lower current I tried an LED rear bulb (18 LED's, including 6 arranged radially to act as a number plate light) in the taillight on my Paso and it was rubbish! Much dimmer than a standard incandescent bulb, with a poor spread of light. The stop light was also very poor, both lights were unsafe to use in my opinion. This bulb was bought on ebay and given to me as a gift so perhaps I shouldn't have expected too much. From the brief research I did it would appear that LED bulbs aren't yet as bright as normal ones, though I hope this will change, apparently 'Luxeon' LED's put out a lot more light and are being going to be used as original equipment in cars. So maybe someone will make a good quality tail bulb using one.
Martin Philp
Paso 750
Posted: Sat Dec 23, 2006 8:20 pm
by Finnpaso
There are VERY manykind of LEDs around, and only ones, what function in such systems are "super bright LEDs". Those have been quite expensive to this time, but now seems, that also those are lower priced and then can used in many light systems around... I would use "light blue" ones in such systems, cause that red, or yellow lense makes right colour to see by eyes and those light blue ones seems to give best brightness... I have tested some...
Posted: Sun Dec 24, 2006 10:27 am
by Rodney
the LED taillights reduce power very little have changed to leds myself but the best way is to put an extra fuse in and run the headlight through a relay if you want brighter headlight worked well for me .
Posted: Sun Dec 24, 2006 6:59 pm
by Finnpaso
Rodney have learnd his lessons quite well...
:laugh: :funny:
Posted: Mon Dec 25, 2006 11:08 am
by persempre907
persempre907 wrote:But, about this matter Antti could say the decisive word
He said it....
:funny: :funny: :funny: :funny: :funny:
Like a Woman improve what you can and work with what can,t
Posted: Mon Dec 25, 2006 8:30 pm
by Marinus
This is what I have done. I have a 2.5mm cable run directly from the battery, through a fuse to 2 relays (one for high and one for low beam) bolted onto the back of the plastic headlight surround. I soldered all connections. I have a 75/80w bulb.
I have also put in higher w bulbs in the dash.
There are other things you can do to like turn the headlight of when starting the bike and only switching it on when you start to make some revs.
Another thing I do is open the throttle a little when you first start to crank the motor as this reduces the vacuum when the system is under the most strain of that first crank over.
Paso is a little like a Woman. Fix or improve what you can and work and learn to love with what you can't.
I have had reliable bikes that need little servicing, they did every thing that was asked of them. I loved them too and did allot of Km's on them and now I find them boring. They were Honda's.
Now I have a beautiful, feisty, high maintenance and temperamental bike that I love to look at, tinker with and ride.
She is like a mistress. She brings out a passion in me that my other rides don’t but I would not like to have her as my main drive and it’s always fun to be with her so long as I don’t ride her for to long.
She is only my mistress but my only mistress!
Re: Like a Woman improve what you can and work with what can
Posted: Tue Dec 26, 2006 3:04 pm
by Finnpaso
I agree that 100% :laugh: MORE harder Your drive, MORE they like it!!!! But surely need maintain quite often, especially, if they are too old.... :funny: :funny: :funny: :funny: :funny: :funny:
Posted: Tue Dec 26, 2006 5:17 pm
by Rodney
had mine in pieces last week after that damm weber blocked up changed to the mikuni carbs made a big difference no stopping at lights and far smoother acceration , easiest change over have ever done on any vehicle.
Posted: Tue Dec 26, 2006 5:23 pm
by persempre907
Marinus wrote:I have had reliable bikes that need little servicing, they did every thing that was asked of them. I loved them too and did allot of Km's on them and now I find them boring. They were Honda's.
For me it has been the same.
I sold my Honda and I bought my Duck!
