907 workshop manual??
Seems to be just one copy of that floating around the Net.
One bad, hardly reprintable copy, w the red pen markings at HP figures on page 3.
After much troble, printed it out today.
Section F, engine disassembly, did not exist.
And more was missin, do I need the 906 whop manual to cover
all that will be needed f a full 907 engine check etc?
Re: 907 workshop manual??
the 907ie workshop manual is the supplement of the 906 ws manual, so you need that, too.
ok as I had some parts to order I ordered the 907 ws manual and the 906 parts catalogue also as this is still missing. I will put them on the scanner when I receive them, but that could take 2 weeks or so.
- Finnpaso
Gerhard, try to have sometimes little freetime!!
actually lately I have lots of time as I decided to quit my old job and look for a new one
So currently I`m arranging all the things I wanted to do the past years and never really found the time for.... and that`s a lot
Very nice thing.
No matter, I have on a cd somewhere, the workshop manual of the 907.
If it can be useful....
try to compare it to the one mentioned. On that scan there`re several handwritten notes in red. (i.e. on page 3). I guess yours is the same.
Yes, I do.
It's the same
It's the same
- du907
Hey guys, The 906 and 907 workshop manuals are on this site under documents, 907IE in pdf format.
Also, if you really aren't satisfied with what you find on this web site, e-mail me, I have already scanned both manuals and have them in pdf format. du907@earthlink.net
check this site first.
du907
du907
the 906 manual is in good quality, just the 907ies isnn`t.
Let me know how big your scan is and I may exchange the file with yours.
- du907
The file is 3.13 MB pdf format.
907IE Workshop Manual
Bryon, the file you sent me is exactly the one we`re talking about.
- du907
That is the condensed file. I have the file in it's orginal scan but it is quite a bit larger. When I get home tonight, I'll send you the larger file and then you can see if it is clearer. Also you can try and condense it yourshelf to a size that will work for the ducatipaso.org site.
du907
du907
I received the original 80MB pdf from Bryon and tried to reduce file size without impacting its quality. It took a while but now it is 22MB.
I have already uploaded it in the download section of ducatipaso.org (907ie/manuals) and removed to old 3MB file. I will add it to my download thread also.
Thx. Bryon for helping out !
